ls1 miata race car build.
![](http://begoodphotography.smugmug.com/Automotive/ls1-miata-build/IMG00387-20100917-1705/1156898266_hpx4J-L.jpg)
![](http://begoodphotography.smugmug.com/Automotive/ls1-miata-build/IMG00389-20100917-1708/1156898313_oMYti-L.jpg)
![](http://begoodphotography.smugmug.com/Automotive/ls1-miata-build/IMG00391-20100920-1513/1156898433_CDBzb-L.jpg)
A good shot of the exhaust and the sfi bellhousing.
Eli from Project X "This stupid thing actually started tonight. Sounds ridiculous."
http://youtu.be/pwbVA5pCq9g
^VIDEO OF FIRST START
![](http://begoodphotography.smugmug.com/Automotive/ls1-miata-build/MG0222/1048922103_6TfNG-XL.jpg)
![](http://begoodphotography.smugmug.com/Automotive/ls1-miata-build/MG0191/1048922770_3V8Lj-L.jpg)
![Talking](https://ls1tech.com/forums/images/icons/icon10.gif)
I have no speedo either. The speed relative to RPM is a constant, so if you know 70 MPH, for example, just remember what the engine is turning.
In this case I'd guess 2000 RPM in 1st gear is like 120 MPH
Interesting take on induction plumbing.....both styles. I'm curious to see what you ended up with on the "final draft". Also curious what accessory setup was used on the front of the engine....I like how the alt ended up easily accessible.
you caught me lol. i did the build a while ago, but i post my build thread and updates in the same thread. i'm an organizational freak like that.
LOL, yah too much was happening in the build too soon.
As to the front anti-sway bar mounts. Did you actually upgrade them & if so was it before or after they fatigued or maybe even failed on you? They are basically the only weak point on a Miata. Mazda actually built a stout car for only having 135 BHP.
i pulled the say bar mounts. the oem location of the sway bar ran it right threw the lsx crank pulley. so i cut them and relocated the bar 2" lower with some steel bar to the frame.
![](http://home.comcast.net/~pewter-camaro/Gallery/stream/images/Pic_1733.jpg)
![](http://home.comcast.net/~pewter-camaro/Gallery/stream/images/Pic_1734.jpg)
![](http://home.comcast.net/~pewter-camaro/Gallery/stream/images/Pic_1735.jpg)
one of the guys on thechicagogarage.com took some pics of me running last year
