Making A/C operational without PCM???
Old Dec 21, 2011 | 07:49 PM
Phantom's Avatar
Default Making A/C operational without PCM???
Who can make it happen for me? I have this
But it doesn't really mean anything to me. I don't want to run a toggle switch or anything like that, I just want to turn my **** to cold and, BOOM, A/C. The vehicle is a 2007 classic silverado. Thanks
Old Dec 21, 2011 | 08:31 PM
psiconversion's Avatar
LS1Tech Sponsor
Is this is a retrofit or an ACTUAL 2007 Silverado. If it is the latter, where is the PCM?
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Dec 21, 2011 | 08:33 PM
Phantom's Avatar
It's an actual 2007 classic silverado. The pcm in the engine compartment
Old Dec 21, 2011 | 08:37 PM
LS1Tech Sponsor
I guess I should clarify. Why do you want to get it to work WITHOUT the PCM?
Jon
PSI
__________________
Ebay Store
Old Dec 21, 2011 | 08:39 PM
Phantom's Avatar
Because I'm making the change to carburetor and have no use for the PCM anymore other than apparently the A/C lol
Old Dec 21, 2011 | 09:07 PM
miker2's Avatar
how will you control ignition,cruise control,and transmission (if automatic ) ?
Old Dec 21, 2011 | 09:12 PM
Phantom's Avatar
I have an MSD 6010 ignition, I'll no longer have cruise control and I have a full manual 4L80
Old Dec 21, 2011 | 09:22 PM
garys 68's Avatar
If the HVAC control integrates the temp (thermostat) control and is 12V, simply route that to a trinary switch then to a relay that powers the compressor.
Or you could route the output of the hi pressure switch thru the low pressure switch then to a relay that controls the compressors.
You need to confirm the HVAC output is 12 V and not a data signal either way.
Old Dec 23, 2011 | 03:18 PM
Pocket's Avatar
The HVAC head unit will send 12v for AC request. Use it to trigger a relay to engage the AC clutch. It would be a good idea to integrate a pressure switch on both the high and low sides, but not required
