flywheel spacer
The trans-dapt part should work. You could also use TCI part number 399753PE. It's similar in design to the trans-dapt part, but is less than 20 bucks. I've used quite a few of them. :-) If you're going to use your stock flexplate, you'll have to elongate the flexplate converter holes just a bit so the converter bolts will line up.
