95 Silverado RCSB to LQ4/4L60e Swap (56k Heavy)
#41
So right now I have hard metal fuel lines, but from the tank to the metal lines there is rubber hose and the same from the metal lines to the tbi. Did you put on adapter fitting at the pump to replace the rubber hose, or did you just get high pressure rubber line and clamp it down good? part numbers would be great if you used adapters
