70 chevelle build
Haven't got a whole lot done lately but here's some pics of what I did get accomplished.
Started cleaning up the ls1.
[IMG]
[/IMG] [IMG]
[/IMG]Then the 4l60e. Had a trans shop go thru it and add a shift kit. They didn't really clean the outside of the case very well. But I did.
[IMG]
[/IMG]This is my mount setup.Speedway Motors relocation plates with Energy suspension mounts.
[IMG]
[/IMG]Thats about it for now...more to come.
[IMG]
[/IMG][IMG]
[/IMG]I used 3/16' steel plate that I had bent on a really strong metal break or
brake.
[IMG][IMG]
[/IMG][/IMG][IMG]
[/IMG]Alt just clears Cherokee steering sector. Should be able to slide a belt on but just in case I think I can get a little more clearance with some careful grinding.
[IMG]
[/IMG]]AC compressor mounted up fine but I may have to change it to one that has the lines out of the side rather than the end....or,another notch.
[IMG]
[/IMG]Evap case seems to have plenty of room between it and the passenger cyl head. Boy I didn't want to loose the ac.
[IMG]
[/IMG][IMG]
[/IMG]And the pan has clearance all around
[IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]Cross member worked out with no mods needed...I had heard many people on here say they had to cut and flip the pad. I guess that's only if your running the T56. Glad I didn't cut it off already.Still need to check the drive line angle.
[IMG]
[/IMG]That's it for now....Stay tuned.
Got my engine all mounted in and have been trying to figure out what to do about headers.Looks like prices start at about 400.00 and go up from there. So I took my none EGR F body manifolds to my machinist and he said that they are a very good design and should be good up to 550/600 HP.I thought that's great if I could just get to clear the frame. So after another trial fit I decided to have the bottom side machined down 3/16" to o" at the top. My machinist said no problem since most of the meat is on the bottom anyway. I got the back Friday and they fit like a glove. I now have about an inch clearance from the frame and they tucked right in to the block. I have "No" clearance issues anywhere. Best 75.00 I've spent in a long time. I,ll post some new pics soon.
I had room around the head, but need the extra room around the spark plugs
BC
https://ls1tech.com/forums/conversio...t56-build.html
