Need help with a GenIII 5.3 swap into a K5
Alright guys, need a little help as I'm starting to prep for my build. Got a torn down Gen3 5.3 and I plan on picking up a 700r4 to go behind it with my np203 transfer case (keeping it 4wd). Just going with a stock build for now with plans for maybe a small cam/some head milling in the future. Here's some questions I'm having;
-What fuel pump/setup should I use?
-Any advice from anyone who's done this before?
-Anyone have a list of all the sensors I need on the engine?
Just looking for any advice or experience you guys may have. Anything is appreciated. Thanks!
Sensor location on Gen III Vortec Truck Engines
1 – IAC, Idle Air Control
2 - TPS, Throttle Positioning Sensor
3 – Evaporative Canister Purge Valve, (EVAP) Not need remove
4 – Knock Sensor connector, two sensors under intake manifold
5 - Map Sensor, Manifold Absolute Pressure
6 - Water Temperature Sensor
7 - Crankshaft Position Sensor
8 – Camshaft position Sensor
9 - Oil Pressure Sensor.
Not shown here
MAF, Mass Air Flow Sensor, located on the air inlet tube
VSS, Vehicle Speed Sensor, located on Transmission tailshaft
Oxygen Sensors, Vortec has 4, two before the cat and two after. Pre cat O2 sensors will be used others will be deleted
Oil Pan Level sensor, Can be removed as well
(NOTE: Pictures C/O Cardinal Fang)
