5.3 Carb questions
Old Jan 28, 2012 | 03:56 PM
98GTnSC's Avatar
Default 5.3 Carb questions
i'm looking at purchasing a 5.3 and am wondering if i do a carb setup if i will need the ecu and computer as well or i could just get the MSD6010 ignition and use that to run it? trying to avoid spending money on parts i won;t be needing. thank you
Old Jan 28, 2012 | 04:50 PM
98GTnSC's Avatar
would the 6010 or LS1 Timing Control Module ignition be able to replace the factory harness so i dont have to purchase it is what im asking. looking to run an Edelbrock intake
Old Jan 28, 2012 | 06:23 PM
LS1MCSS's Avatar
Depending on the year model of the engine, you will need the 6010 or 6012. The box will come with the correct harness.
Old Jan 28, 2012 | 06:48 PM
98GTnSC's Avatar
i believe it came from an 04-05 silverado. believe that would be the 6010 if im not mistaken. so that ignition will contain all of the harness components that will be needed to wire it up? thanks for any help as im going to check the engine out tomorrow
Old Jan 28, 2012 | 07:02 PM
78 l92's Avatar
6010 is correct for those years and it comes with box, harness, datalink cable and program so you can set ign. timing
Old Jan 28, 2012 | 07:42 PM
MikeFSKSpeed's Avatar
Yes, 6010 is for the 24x crank, 6012 is for the 58x
98GTnSC's Avatar
thanks guys. going to go look at it tomorrow night
Old Jan 28, 2012 | 07:50 PM
If you wind up needing that MSD box, pm me for a deal!
Old Jan 29, 2012 | 02:56 PM
98GTnSC's Avatar
will do man. gonna go check it out in a few hours. if i can get it at a descent price i'll be bringing it home to sit in the shop til i get my foxbody build underway! 87LX Hatchback with T-Tops
