holley oil pan on G body ?
Old Feb 1, 2012 | 09:04 PM
montecarloss's Avatar
Default holley oil pan on G body ?
Has anyone used the holley oil pan in their g-body?I have hummer pan on my car and it scrapes over bumps.any pic and performance point of view will be helpfull.
Old Feb 1, 2012 | 11:13 PM
NBM-WU8's Avatar
I can try to get you some pictures of the Holley pan in our '88 SS when I get a chance. Can't tell you much from a performance standpoint since we haven't got the car running yet though.
Old Feb 1, 2012 | 11:17 PM
the_merv's Avatar
Veteran: Air Force
How low is your car? Mine hasnt scraped on anything..hopefully it doesnt..but then again I'm not slammed.
Old Feb 2, 2012 | 11:49 AM
NBM-WU8 thanks man
the_merv, I have drop spindels up front and lower spring on back.With the 6.0 and the magnacharger it seats very low.look here
https://ls1tech.com/forums/conversio...nacharger.html
Old Feb 2, 2012 | 03:40 PM
the_merv's Avatar
Veteran: Air Force
Ya you are lower than mine..good lookin car.
Old Feb 2, 2012 | 05:58 PM
NBM-WU8's Avatar
Here are the pics Monte. Sorry some of them are dark but it should give you an idea. Keep in mind these are using the BRP Mounts...
With a straight edge on the crossmember, the sump of the pan sits about 1/2" above the crossmember.
Old Feb 2, 2012 | 06:36 PM
the_merv's Avatar
Veteran: Air Force
That's pretty nice..
Here is the H3 Pan..Conversion Plates, stock Mounts & Clamshells.
I'm goin to eventually weld up a 1/4" steel skid plate..how much was the Holley one? Specs?
Old Feb 2, 2012 | 07:07 PM
NBM-WU8's Avatar
I believe it was around 350 when we bought it but I don't remember exactly. Holds 6 quarts with filter.
Old Feb 2, 2012 | 07:30 PM
LS1MCSS's Avatar
This car has the Holley pan on an LY6. I am pretty sure that it's no lower than the cross member.
http://smg.photobucket.com/albums/v3...1150819_1_.mp4
Old Feb 2, 2012 | 07:44 PM
llorracs93s10's Avatar
Damn, I think I am going to get me the holley pan....Merv, thats too low for my tastes. I like my cars low, and id scrap my pan on this bump which resides right outside my house....lol
Old Feb 2, 2012 | 07:48 PM
NBM-WU8, those are some perfect pic man.am going to buy a holley pan.
the_merv ,that's how my hangs
LS1MCSS,that's a nice build and good hp on manifolds
Old Feb 2, 2012 | 07:57 PM
NBM-WU8, do you have the part #'s for the pickup tube and oil dipstick?
Old Feb 2, 2012 | 08:05 PM
NBM-WU8's Avatar
Pan comes with the pickup tube. Requires use of LS3 dipstick (GM P/N 12634547) and tube (GM p/n 12625031) (taken from holley website)
Also, here are the install instructions.http://holleyparts.net/data/Products...R10566rev2.pdf
It will require a new windage tray unless you want to cut yours up to make it fit
Old Feb 2, 2012 | 08:29 PM
thanks again
Old Feb 3, 2012 | 01:38 PM
01cherryreds10's Avatar
Thanks very much for the pictures I think I'm gonna get the holley pan as well and sell the musclecar one
Old Feb 4, 2012 | 08:25 AM
Screamer27's Avatar
I'm running the CTS-V pan, I had to notch the cross member, but I hang as far down as the Holley Pan. I'll try to get pics tonite.
Old Feb 4, 2012 | 10:28 AM
the_merv's Avatar
Veteran: Air Force
I guess it's the way the Cradle is shaped in these cars..I use the same pan in my S10 and the bottom of that H3 Pan is flush with the Cradle..
Old Feb 4, 2012 | 11:41 AM
uneek1976's Avatar
What's the difference between the holley, h3, and the gm muscle car pan?
Old Feb 4, 2012 | 06:42 PM
the_merv's Avatar
Veteran: Air Force
H3 and the GM Muscle Car Pan are the same thing, the Holley shows the difference in the pics..and from what I've read about $200 more easily.
Old Feb 4, 2012 | 07:18 PM
T76s10's Avatar
Isn't the ctsv pan supposed to be the best choice for g bodys?
