F-body Accessories in a Chevelle?
I'm looking for accessories for an LM7 for my 1970 El Camino I am using Edelbrock adapter plates, with stock frame mount height and location, and was wondering if the f-body accessories (no AC) can be mounted on it without any modifications. What kind of clearance is there between the alternator and the steering box? any pictures would be greatly appreciated
Also has anyone tried the L99 accessories from the 2010 Camaros?
Thanks in advance
Thanks in advance
El S1 Camino - check my build thread. I have a complete set of F-body accessories, and I am placing the motor in the "standard" location. The alternator and steering box have some major interference with that setup. Moving the motor 1" or so back would help greatly, but would probably still cause trouble.
I am going to go with the KWIK alt/ps bracket.
I went with the corvette FEAD, but I bought it brand new. The alternator is on top and the ps pump is below it. As you can see it doesn't interfere with the steering box. I have the LS3 in a 70 Monte Carlo. I think the Vette feed allows more room since none of the accessories interfere with the K-Member or steering box. I went with this set up specifically because I wanted AC and the Kwik AC brackets puts the compressor up top on the passenger side.
http://paceperformance.com/i-6485405...7-engines.html
Biggest interference problem on this is the alternator and the steering box.You cant hardly get the engine far back enough to clear the steering box with f body accessories.You can raise it up enough to get by using brp motor mounts,but you cause other problems like trans tunnel clearence when you do.If you use corvette acces. that puts the alt.up top you will save yourself some grief.Everything else f body works great on the chevelle except the oil pan which will have to be notched or use different pan such as holley,mast,etc.Most of the other factory pans will hang a little too low,truck, hummer,ctsv,etc.
Thanks for the replys.
Does anyone know it the mounting location of the alternator on the new camaros is any tighter to the motor to give more clearance between it and the steering box then the regular f-body setup?
