GM T56 in a fox-hydralic or not?
Old 10-08-2011, 12:38 PM
93hatch's Avatar
Default GM T56 in a fox-hydralic or not?
Are you guys who have swapped a t56 in your fox running it with a slave cylinder or not? Would prefer not to but if I have to I will
Old 10-08-2011, 03:25 PM
zipster's Avatar
I used the Wilwood. check out the photobucket.
Old 10-08-2011, 04:16 PM
79LS1FOX's Avatar
Default hydraulic clutch actuation
I tried for 3 months to use the cable operated system with no luck, ended up buying parts and pieces from Kiesler and made a bracket to mount the master to a Turbo coupe pedal box works real well. If I was going to do it again I'd go with the McLeod system, even though its expensive as hell, you get to keep your stock cable operated pedal box and there is absoutely no fabrication, wish it was avaliable when I did mine!
Old 10-08-2011, 07:20 PM
93hatch's Avatar
fak not soundin good
Old 10-09-2011, 01:24 PM
93hatch's Avatar
maybe I can run a tko600 without a slave set up
Old 10-09-2011, 11:32 PM
itsslow98's Avatar
Im running turbo coupe pedals, with a mcleod clutch master. I had to make a mounting bracket for the master but that was the extent of the modifications to make it work perfectly.
Old 01-30-2012, 02:14 PM
glhs422's Avatar
(Resurrecting old thread)
Has anyone used this Mcleod hydraulic conversion kit for Fox body stangs?
Could this be used in an LSX/t56 fox swap?
http://www.mcleodracing.com/info/?id=5317
Old 01-30-2012, 04:16 PM
79LS1FOX's Avatar
Default mcleod setup
I really dont see why not, T56's and TKO's are pretty much the same up front where the TO bearing mounts.
Old 01-30-2012, 04:58 PM
glhs422's Avatar
I assume you're referring to the complete McLeod hydraulic conversion system? (http://www.mcleodracing.com/info/?id=5317)
#1 In the above case, you would use the STOCK fox body 5-speed pedal assembly, right?
AND
#2 In the case of using the McLeod master cylinder alone (http://www.jegs.com/i/McLeod/673/139301/10002/-1), you would use the Turbo coupe 5-speed pedal assembly, right?
Old 01-30-2012, 10:26 PM
N20neenee's Avatar
Thats the camaro specific MS that you are showing and its at an angle. Wouldnt you want an MS that sat flush with the firewall and not angled?
Old 01-31-2012, 08:11 AM
speedshifter's Avatar
McLeod #14-330-01 clutch master cylinder kit is meant to connect to a quick connect slave cylinder. Its the one i have on my wish list for my viper tr-6060
Old 01-31-2012, 08:51 AM
Mr. Hyde's Avatar
I have $350 in my setup...willwood master, T-Bird turbo coupe pedals, McLeod quick disconnect line to connect to slave...fabbed bracket to hold the master and done. It's pretty easy considering...and I'm a moron.
Old 01-31-2012, 07:00 PM
glhs422's Avatar
Sweet! Can you post up a link to which Wilwood master you used?
Old 02-08-2012, 11:26 AM
Mr. Hyde's Avatar
Oops, sorry I forgot to come back and check this thread
Google Wilwood remote master cylinder...I used the one that had similar bore/stroke as the factory f-body one...it's been several years but I think it was this one: http://www.summitracing.com/parts/WIL-260-3374/
I ended up having a buddy fab a neat aluminum remote reservoir instead of the cheap plastic eyesore they include in the kit.
Old 02-08-2012, 12:54 PM
glhs422's Avatar
Thanks!
Quick Reply: GM T56 in a fox-hydralic or not?
