1969 CAMARO RS LS2 Swap - Need Help!
Hello All,
Thank you for reading. I appreciate any help in advance.
Finally making the plunge to pull the small block out of my 69 camaro and replace it with a LS2 out of a GTO. Motor arrived with the t56 and I'm dying to get it in.
the project began as a thought and VERY QUICKLY became reality as I found a motor at a great price with all accessories.
I've gone online and read different threads trying to figure it all out. I have a shop who is ready to do the swap, but in order to save some money I'm doing all the leg work and research to make it an easy install (relatively speaking).
https://ls1tech.com/forums/conversio...ml#post4073808
this thread has been a great help.
ATS seems to have a good set of mounts but i want to make sure they will work with the header setup. which brings up the next question. What headers to go with?
http://www.summitracing.com/parts/CM...ComboContents/
this is a kit some recommended on the boards which includes the pan and all.
Does anybody have some insight on any of this?
Trying to figure it out but there are obviously MANY combinations. I'm not on a super tight budget but don't want to waste money.
PLEASE HELP!!!
Thanks!
PLEASE HELP!!!
Thanks!
I would say the best way to avoid any issue is to use a complete kit from one Manufactor.. or from one vendor that has peiced together parts as a Kit.. as Summit has. As long as Summit has installed all of the part, it might be a timesaver to use it, althought it doesn't include any Transmission X-Member.
I am supprised that Summit didn't use the Hooker Adapter plates along with the Hooker Headers that are in their kit.
You should also note with that Milodon pan, you will need to run a remote Oil Filter. If you don't want to go with the Steel pan and remote filter, I would suggest the MAST or Holley Pan the have the oil filter in the OEM location..
Other vendors to check on would be S&P and BRP. Andy yes the ATS plate are good.
Have you read the FAQ on 1st gen F-Body.. that might help some to see who and what they are using.. it really comes down to what you want...
BC
BC
BC
BC
