Using Ford rack with stock LS pump = disaster. Help!
Old Feb 8, 2012 | 08:40 PM
Jemo's Avatar
Default Using Ford rack with stock LS pump = disaster. Help!
Well, I almost made it. I started the truck up tonight really for the first time. It ran great and then my son pointed at the ground and there was PS fluid flowing onto the garage floor and sprayed all the way to the back of the truck! AHHHH!!! This was a brand new rack that came with the TCI Mustang II front end. I'm pretty sure it blew the seals because it doesn't look like it's leaking out of any of the fittings.
From the forums I just read, they all recommend Borgeson P/N 899001 to reduce the pressure. BUT, is that really the problem?! Since I wasn't turning the steering wheel, there should be no pressure to speak of in the steering system if everything was connected correctly and the parts were not defective. If I was building pressure just by running the engine, something is probably wrong! - the return hose is blocked, the rack is contaminated, something like that but I don't see anything.
I know Heidt's also sells a valve for Ford rack/GM pump installations but real unsure where to go now.
One thing I will say that we noticed when we tried to start the truck on the weekend, the front end shook violently in the beginning, enough to turn the wheel . We thought maybe it was because it was the first start and there was air in the lines.
I put it together so long ago, I don't remember if the fittings were the same size but I don't believe they were. Meaning, it wouldn't be possible to put the return on the supply side and supply on return. IF it was reversed, is this what you'd suspect? Does anyone know for sure which port is supply and return on an early 80's T-bird rack?
Jeff
Old Feb 8, 2012 | 09:03 PM
oldngray's Avatar
Default line position
Get in touch with UNisteer, they are up on the pressure/volume needed for the situation you have, can also tell you the pressure /return position on your rack...
Old Feb 9, 2012 | 09:34 AM
Mike52's Avatar
Jemo, it is a pressure problem, it's a mismatched pump to rack issue. It's known that the GM pump creates too much pressure for the Ford or Omni style rack and pinions. The violent shaking and the wheel turning you mentioned on start-up was most likely due to the extreme pressure the pump was supplying to the rack which in turn caused the seals to pop shooting fluid everywhere. Several sources offer a pressure reduction valve (such as the Heidt's valve you mentioned). The rack and pinion on my '32 Ford coupe TCI chassis (rear steer) is a Unisteer Dodge Omni style, it's a manual rack so I don't have the pressure issue. Do as oldngray suggested, contact Unisteer (or the manufacturer of your r&p) tell them what happened, in case of possible damage to the rack, then follow their recommendations. I can assure you, you will need the pressure reduction valve but you will need to find out which one to use with your pump/r&p combo.
I've also seen instances on lightweight hot rods where slightly too much pump pressure will make the car feel 'twitchy' going down the road, a reduction in pump pressure cures the problem and makes them drive normal.
Hope this help.
Old Feb 9, 2012 | 09:43 AM
beach cruiser's Avatar
I'm running an LS1 pump on my 67 camaro with the Ford Rack from a foxbody. I sent my pump to turnone to install the reduction valve and work thier magic on the rest of the pump. They say they do it all the time, but I can't swear on it because I havn't fired off the engine yet.
Old Feb 9, 2012 | 03:41 PM
DirtyDirk's Avatar
Do you need to reduce line pressure on a 94 impala gear box with 04 vette pump?
Old Feb 9, 2012 | 09:39 PM
S10xGN's Avatar
Jeff
Jeff,
I have this same combo in my Maverick. I ran mine for awhile w/o any "reducer valves", just straight full-flow fittings and never had any issue with blown seals. I did, however, suffer the "shakes" like you did while trying to bleed the system and that's what convinced me to add the DSE valve in the pump outlet. See if you can exchange the rack and try again...
Old Feb 9, 2012 | 10:13 PM
Jemo's Avatar
Thank you all for your replies. I called Unisteer this morning and the guy straight away said if it was shaking the way it did, I had the hoses reversed. He said the pump at normal pressure wouldn't blow the seals on a ford rack that quickly. I spent 2 hours tonight removing the old rack. No idea how I'm going to get the new one back in but it was only $79. One step forward, two steps back. Jeff
Old Feb 10, 2012 | 03:02 PM
CameronVic's Avatar
Does this only happen with racks? Because I'm about to put a 5.3 in and use the chevy pump on my stock ford steering gear.
Old Feb 10, 2012 | 09:30 PM
S10xGN's Avatar
It can happen when a Ford rack is used with a GM pump due to the difference in pressure/flow requirements. The fix is a $20 part from DSE (or others).
Old Feb 10, 2012 | 10:31 PM
Jemo's Avatar
I just found a video on youtube that shows how to install the shims.
Search for: "Power Steering Pump Pressure Reducing For Your Mustang Rack and Pinion"
**Beware of language used in video** Just lettin' you know.
Old Feb 11, 2012 | 09:20 AM
zipster's Avatar
I watched the video, they could of condensed it into a 5 min spot if they were not screwing around. Very professional.
Old Feb 11, 2012 | 03:17 PM
CameronVic's Avatar
I know, i got all that from the earlier posts in the thread, I was asking if a steering gear (recirculating ball) will suffer the same way a rack would.
Old Feb 11, 2012 | 09:05 PM
S10xGN's Avatar
Actually, you said "stock ford steering gear". Nothing about recirculating ball... Anyways, I don't think the old "box" type units suffer the same problems that racks do.
Old Feb 12, 2012 | 04:47 PM
CameronVic's Avatar
I've never in my life heard a rack and pinion referred to as a "steering gear". I didn't mean to confuse you, nor was I trying to be "rude".
Old Feb 12, 2012 | 07:44 PM
S10xGN's Avatar
I didn't take it as rude, it's prolly just a "generation gap" thing. Us old guys grew up calling everything from the steering wheel to the spindles "gear", just as a camper or rock climber would call all his stuff "gear". "Gear" is a loose term that covers a multitude of parts...
Old Feb 12, 2012 | 08:39 PM
CameronVic's Avatar
And peace has been restored on LS1 tech!
