M12x1.5 to 1/8NPT Steel Adapter
My existing brass temp adapter is weepeing coolant. Can't tighten it anymore, as I'm afraid to break it. I broke one before even after being warned about how fragile they are, so I want something stronger than the EQUUS brand. I believe someone makes one out of steel. Anyone know who makes/sells it?
Thanks,
Andy1
Thanks,
Andy1
My brass adapter uses a crush washer. After some surfing, I see some brass adapters use an O ring seal, so perhaps it doesn't need to be tightened as musch as the crush washer version. Anyone use the O ring version?
Andy1
Andy1
It never occured to me to check McMaster-Carr. I see they do list one in steel, though for a M12 x 1.5 it only lists a 1/4NPT so I'd have to reduce it. I'm more concerned with the thru hole diameter being adequate to accept the water temp sensor protrusion (though I can drill out the ID). Price is $13.53, plus the cost of a reducer.....but I'm not complaining.
Andy1
Andy1
Andy1
Andy1
http://www.mcmaster.com/#cadinlnord/4936k154/=gcj3oe
If it is drawn to scale then it looks like the pass through hole is 5/16 inch.
