Oil pan clearance problem...
My question is... are there different oil pans for the LS1? Basically, I need something that has just a little smaller sump area...
a little less like this... [__/----
and a little more like this... [_/-----
Does that made any sense at all?
I think a mere inch would do the job but I'm thinking the more, the better. I'm wondering... I haven't had the pan off of an LS1, nor have I seen a picture of one with the pan off... but was wondering... if it would be possible to take a stock pan, and modify the sump area to clear the axle EXACTLY how I want it? How is the oil pick-up on the LS1? Is it set up in a way that this could be done? Cut the pan and have a new front wall TIG welding into place? Would I need to have the sump area widened to compensate for the oil capacity of the pan? Are there other pan styles on different LS1 vehicles? If so, which might work? Is there someplace online I can view side by side or scale pictures of them? I have looked around a little already, and will continue to look but if someone has suggestions... I'd REALLY appreciate it! I found my second glitch...
Thanks in advance.
http://www.montecarloss.com/ls1montecarloss/LS1fbodypanPnotch.jpg
(It won't show, so here is where it is located... not sure if it can be viewed without going to his page... the link is towards the top... 01/02/01... last passage, and last link)
I know the pan is structural... so what is the consequence of doing this? Can it be done? Is it a bad idea? I also for the fun of it did a search on dry sump pans... not sure if I wanna do that... not cheap and then I need a scavenge pump and stuff. Not sure how that would work out.
Anyway, I'll continue my search. but if anyone has ideas... I'd love to hear them. Thanks!
Which pan are you using?? If it is the Camaro pan, you MIGHT want to try using the Truck pan since this is going into a 4x4. The Truck pan already has the sump further back than the Camaro pan does... but the front part BEFORE the sump hangs a little lower, as does the entire sump itself. So, if your only issue is the front part of the sump hitting, but you have plenty of clearance UNDER the pan... it would probably work for you.
This is from S & P's website... at the bottom of the page, they have diagrams of the different pans. You can see what I mean about the truck pan.
http://www.hotrodlane.cc/onlinecatal...alogpage61.jpg
http://community.webshots.com/user/ironmanvx2000 (<---EDITED)
TTYL!
Coach... I mean Randy (I often forget who I really am)
Undergoing LS1 Conversion as we speak!
Click Image to Visit My Website!
TTYL!
