68 chevelle goes under the LS knife.
Old 03-31-2012, 09:06 PM
  #61
68BBChevelle's Avatar
Originally Posted by 99VetteFRC
Wow. Not really sure why the alt hits, mine doesn't. I have SS hood and probly 105amp alt, but all my stuff clears, even the Vortec engine cover.
Was wondering how you made out with yours. Doubt ill get that luck it just dont work out that way for me lol.
Old 03-31-2012, 09:12 PM
  #62
99VetteFRC's Avatar
You think I have good luck? Second motor in two weeks, trans broke twice..... Need I say more? ROFLMMFAO
Old 03-31-2012, 09:18 PM
  #63
Old 04-01-2012, 02:17 PM
  #64
Well got it all wired up today, and all my misc. Stuff done. Turn the key fuel pump came on tried to start it and nothing it just cranks. Got fuel at the rail but no spark. Plugged mt scan tool in and got code p1336 crank sensor relearn. Anyone know how to fix this?
Old 04-01-2012, 04:38 PM
  #65
99VetteFRC's Avatar
What kind of scan tool are you using? Tech2 and Snap On have crank relearn in the generic functions area. I didn't have to do that. Plus I looked into it and I needed to have the trans and parking brake wired into the PCM.
Old 04-01-2012, 05:34 PM
  #66
I'm using a craftsman scan tool. I did put 12v to brake wire while cranking but it made no difference. I had him set me up as I was using the t56.
Old 04-01-2012, 06:29 PM
  #67
99VetteFRC's Avatar
I tried to do that on mine, even though it was running ok, but it asked for a whole bunch of things that I didn't have so I didn't do it.
Old 04-01-2012, 06:45 PM
  #68
Guess im going to call Jon in the am and see what he says.
Old 04-01-2012, 07:08 PM
  #69
99VetteFRC's Avatar
I think I remember the Snap On scanner wanting the car to be in park with the e-brake on. If your PCM was set up for manual it may be looking for e-brake switch signal and maybe clutch switch engage signal.
Old 04-01-2012, 07:16 PM
  #70
Yeah ive read that in few other threads and guys are having problems with the gm scanner too not reconizing the ecm to relearn the crank. Ive also read some tuners delete that code rate out of the ecm. I did apply power to the brake swith wire but still had nothing. Im out of ideas guess ill let the man that made it figure it out.
Old 04-01-2012, 07:23 PM
  #71
99VetteFRC's Avatar
LOL, if I can remember, in the morning I will hook the Snap On to the Vette and see what it says to do. I'll let you know. I do think the car should start and run though. The car has to run to do a crank relearn. You will need to get it running before the PCM knows the differance between the crank and cam. At least thats how I remember when I worked at Chevy 10 years ago.
Old 04-01-2012, 08:22 PM
  #72
Ok cool that would be great. Only thing holding me back from starting is no fire to the plugs.
Old 04-01-2012, 08:36 PM
  #73
99VetteFRC's Avatar
HHMMMMMM!! I'm sure that is not a crank relearn problem is the issue. If I remember correctly the car has to be running for the crank relearn. I would check and make sure you are getting 12v to the coils and then check for ground signal from PCM. Noid light is the easiest way same as injectors. I really think something else is wrong other than the crank relearn for the car not to run.
Old 04-02-2012, 09:21 AM
  #74
The car has to run to do the crank relearn correct? I checked with my volt meter at the coil pack plug i have 12.6 volts on the pink wire all others are dead. I can get a reading while cranking cuz by myself rate now? I just need to figure out why no fire then it should run.
Old 04-02-2012, 11:42 AM
  #75
99VetteFRC's Avatar
So you are getting 12v to the connector on the valve cover where the coils plug into but not at each coil individually? That means either the connector is pinned wrong(different year maybe) or there is a splice after the connector bad. You shouldn't have to crank the engine to see if you get 12v at each coil connector. You may have a bad ground too.
Old 04-02-2012, 01:34 PM
  #76
Yes 12v to the main coil plug but not each coil. Im sure each coil is pinned right nothing on them has change unless my new harness is wrong. I have checked all the grounds that was the first thing i did. Talk to Jon this am he had me check few things like the wire for ignition relay if i have power switched and cranking. I do with key on but not while cranking. Im thinking thats my problem it loses power when i go to crank, shouldnt it be hot while cranking too?
Old 04-02-2012, 06:44 PM
  #77
Its ALIVE!!! Rookie mistake got it going i didnt have power to the ignition relay while cranking, added power and bam shes running. Im siked just got to get ps pulley on, belt on ,and then get to an exhaust shop and Im riding.
Old 04-02-2012, 06:50 PM
  #78
99VetteFRC's Avatar
Bad ***!!! Is it going to the beach? I got my number today, 1420!
Old 04-03-2012, 09:53 AM
  #79
http://www.youtube.com/watch?v=1egMZ8JAnPs
Old 04-03-2012, 09:55 AM
  #80
Yeah man the beach is still the plan, i didn't sign up for the inlet.
Quick Reply: 68 chevelle goes under the LS knife.
