Is there a way to start up an engine on a stand?
What all do I need to hookup To get it started.
It comes with an engine harness and ecu and all accessories I read vats has to be disabled.
Also are 4.8 and 5.3 ecu's compatibles ?
I really like to hear an engine run before I commit to all the work and it be a bad engine.
i did mine with a old battery, old fuel pump+gas can and some other odds and ends = but mine was a turnkey engine
it might be possible to bypass the pcm/stock harness/ and use some kind of gasoline squirt bottle into the throttle body (to hear it run for a few seconds) but i have no idea (someone else would have to chime in on that one)
http://www.youtube.com/watch?v=a0AR_...4&feature=plcp
http://s704.photobucket.com/albums/w...filter=noflash
I highly discourage starting any engine on an engine asembly stand without a radiator and fuel system. No safe at all. Plus you can't test the injectors.
VATS MUST be deleted in the PCM file OR a VATS bypass module used. The bypass module is not the best way considering most swaps delete all the emissions devices so the check engine light will be ON and all the associated codes will be set in the PCM and show on a scanner. Kind of defeats the whole purpose of doing a clean efficient swap. But it will run for less than 3 seconds if even that long.
I use an inline Walbro pump but you can use any junk yard used in-tank or inline pump as long as you run a filter. no sense shoving stale fuel that's been sitting in the fuel rail and injectors right into the injectors. I always soak and clean them before running a used engine.
By disconnecting the Cxxx. It made it easy for GM to raise the engine into place or for the dealer to drop the engine out to sercices the car/engine.
