4l60e trans fitting question
Old Feb 29, 2012 | 08:54 PM
spot_55's Avatar
Default 4l60e trans fitting question
I am wondering if I can change the trans lines fittings to ones frome a 350 turbo and them not leak? thread pitch appears the same as does the thread length.
Old Feb 29, 2012 | 09:05 PM
LS1MCSS's Avatar
Yes you can. I put 1/4" npt to -6an in my tranny and they don't leak.
Old Mar 1, 2012 | 06:19 AM
spot_55's Avatar
Thanks for the reply,I was hoping i could put the old fittings in there. Don't care much for the push in and clip setup.
Old Mar 1, 2012 | 09:23 AM
bczee's Avatar
The thread on the 4L60E is 1/4" NPS (straight) not NPT, you should use the NPS fitting with a steel/brass gasket (as your stock one is). You can get away with using a NPT, but if over thighten, you can crack your Trans Case.
BC
Old Mar 1, 2012 | 10:49 AM
nos487's Avatar
I am going to use these with some braided hose.
http://www.ebay.com/itm/270452549292...#ht_500wt_1054
Old Mar 1, 2012 | 10:55 AM
bczee's Avatar
Those will work and have the correct Threads.. AN -8 = 1/2" line...
Old Mar 2, 2012 | 11:29 AM
74novacustom's Avatar
BC
This is correct! mine came with nylon washers.
Old Mar 2, 2012 | 12:00 PM
bczee's Avatar
NOS487.. is there a reason your going with AN -8.. bit of an over kill for most applicaiton unles your racing or something or have a problem of overheading and trying to increase flow and cooling ? Most cars / trucks use 3/8" / AN -6 fitting and lines.. but its not a problem going AN -8.
Just asking as I about to start on my Trans lines soon.
BC
