lq9 injectors on ls6 intake
Actually, I wish I would have thought about spacers when I did my Olds build. I've got a spare LS1 rail and could have made that work with $30 spacers rather than a $100 aftermarket rail. The aftermarket ones do look purdy..... but I would rather spend $70 on something else.
Why would you want to use truck injectors? I put stock LS1 injectors on a truck intake with stock truck rails, just spaced the rails bolts about 3/8" with metal brake line I cut. the connecters are super cheap on Ebay.
For me it was because I started off with a truck motor, truck harness and I have two different sets of truck injectors and the connector/pigtails to run either one I wanted.
I didn't have ls1 injectors in hand nor the ev1 connectors to wire in so I could use them.
But lucky for me I scored some.. what are supposed to be very low mileage ls1 injectors and now just need to go junk yard diving for ev1 connectors/pigtails to wire in.
Hood clearance wasn't a issue for me though. I could run truck intake no problem.
