Turbo with MAF
you will need to invest in a 2bar os for that 2bar map to work. it is another $100 from hptuners.
i see on my tune there is something called offset which i have at 10(kpa). not sure if that is correct and it likely varies for each sensor but it is working so i am leaving it alone.
tuning is kind of tricky and then tuning a boosted set up with a 2bar sensor adds a few steps to your normal tuning. you are going to have a steep learning curve. take your time, do not just go out and floor it no matter how badly you might want to.
log stuff like timing, knock retard, a/f ratio. you will need a wideband and you will want to figure out how to tie it into the computer so you can log it with everything else.
Have seen this done on MAF'd Procharged set-ups a lot.
Good luck man...killer build!
Dave
Dave
I'd rather enjoy my car for now then let it stay laid up for months.
BTW, you have any more pics of your car's paint job...just realized where I got my inspiration for my 442's paint job....your car!!!
Dave
Dave
I guess I should upload some to an album.
if it were mine i would just do a 2bar os and speed density only. it should offer you rtt(real time tuning) which makes tuning sd faster.
i just looked at your tune again. if i am reading it right it does look like you have an os enhancement but it isn't to a 2bar.
