EBay Radiators
Old Apr 23, 2012 | 09:19 PM
  #41
bczee's Avatar
Pat,
Nice job on the fab work. Did you ditch the Vette type center air setup...? thought you were going that route ?
Anyway.. should be much better when we are driving around Reno and Tahoe this August !
BC
Old Apr 23, 2012 | 10:38 PM
  #42
Stu Cool's Avatar
Originally Posted by S10xGN
Pat,
I'm pretty sure you won't drive that car in the rain intentionally, but if you do get stuck in it, be wary of sucking enough water to possibly hydraulic the engine with that intake so close to the ground...
Thanks, Yes I am aware of that possibility and I believe I will be fine as long as I avoid any deep standing water. If you remember the original Ram Air 442 had a similar pick up and there are several CAIs for Corvettes that pick up low too.
Pat
Old Apr 23, 2012 | 10:44 PM
  #43
Stu Cool's Avatar
Originally Posted by bczee
Pat,
BC
Once I started trying to make that work, I decided I just did not have the room to put the filter up there in a way I was comfortable with. I find myself wishing I would have set my motor back and inch or two when I put it in there, too late to change that now.
Pat
Old May 18, 2012 | 07:45 PM
  #44
Stu Cool's Avatar
I finished the painting and got everything re-installed. Also repainted my bumper and lower air scoop to take care of some road rash. Declaring this project done for now. I also reworked my lower radiator hose. Got a 1.75 - 1.5 reducer from Jags that Run and used the top half of my old hose along with a newer bottom hose to get all the angles right. The first hose I tried was close, but was kinking a little bit and I was afraid it was collapsing. changing the hose made a 10* difference at highway cruise speeds.
Now that I have cool intake air I think I will take it to the Wednesday night street drags and see if it helped.
Pat
Old Jul 26, 2012 | 12:55 PM
  #45
emc53's Avatar
Pat, enjoy reading your posts. I have an lt1 in my stude now and am planning on changing it to an ls1. I have most of the parts, just getting ready to start.
Old Jul 26, 2012 | 02:32 PM
  #46
bczee's Avatar
emc53.. I have personally seen Pats car and it is a very good car to study and use to build off of.
Pat... see you soon in Reno !!!
BC
Old Jul 27, 2012 | 05:40 AM
  #47
Stu Cool's Avatar
Glad you are enjoying my stories. If you haven't seen it it before I have a build journal here: http://www.hotrodders.com/forum/jour...ournalid=33611
By the way I am driving the Stude across country to South Bend for the International meet right now. I am not very happy with this radiator I installed. It does not have sufficient capacity and I have been having over heating problems that I never had with the old down flow radiator :-(. So back to the drawing board if I make it back home without burning the darn thing up. here is a picture at the Bonneville Salt Flats.
Pat
Old Jul 27, 2012 | 07:11 AM
  #48
pmgm's Avatar
You have a nice car. Rad sway came out nice.....
Old Jul 27, 2012 | 07:43 AM
  #49
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Bummer is it over-heating on the highway?
Old Jul 27, 2012 | 09:32 AM
  #50
LILHEMI's Avatar
hey can you post part numbers for those hoses? i bought the bigger radiator from those guys and i think the hoses you have might work. thanks.
Old Jul 27, 2012 | 09:43 AM
  #51
Moter's Avatar
I read through this thread about the ebay cooling system parts. I went thru a similar build a couple years ago in that I purchased a chinese radiator off ebay...and had the same problems you are having.. poor cooling. So in my latest build I am using a Griffin radiator. Live and learn...cheaper is not always better.
Nice car and nice build!
Old Jul 27, 2012 | 10:06 AM
  #52
rockytopper's Avatar
Pat
COOL PIC COOL
Did you tester for top speed while you were there?
Old Jul 27, 2012 | 03:30 PM
  #53
emc53's Avatar
Pat, I am running a Griffin in my car now and I am very pleased with it.
Old Jul 28, 2012 | 08:11 AM
  #54
Stu Cool's Avatar
I noticed a rise of about 10-15 degrees compared to my previous brass down flow when I first installed it. At sea level I does ok driving down the highway on level ground with AC, runs about 205-210 on a hot day. In the desert on long steep hills, temp starts climbing and will go right up to 250 if you are not careful. Coming across Nevada I found if I turned the AC off and drove 65 it would stay about 210. I had to slow to 55 on hills or temp would go up. Yesterday I drove from Laramie WY to Bellevue and was able to drive 75 mph all the way with it never going above 205. Out side temps were in the low 90s in the afternoon. I did not run the AC at all for fear of running the temps way up again so we just kicked it old school with arms out the window. Last night I found the vacuum hose had popped off my PCV so it had a big vacuum leak, probably had it running lean, but the computer should have compensated for that. Fixed the hose and clamped it, will see if that makes a difference.
lilhemi, I don't have the part numbers for the hoses handy, in fact the bottom one is two hoses joined by a 1.5 to 1.75 adapter from Jags that Run. To find the hoses I went to my favorite auto parts store ( A real one where they don't have to ask if it has AC and auto transmission when you buy a hose clamp.) and they let me study their big Gates Hose book. I bent a coat hanger in the shape I wanted and measured the length. The Gates book is organized by inlet and out let sizes and length and has pictures of each hose. When I found a couple that looked they would work, the counter man took me back into the bowels of the parts shelves and we looked at the ones I found in the book till we found ones that worked. Was a little tedious but the hoses fit pretty well.
Leaving Bellevue today for Audubon Iowa, then on to South Bend Indiana on Monday for the Studebaker International Meet.
Pat
Old Jul 28, 2012 | 09:01 AM
  #55
LILHEMI's Avatar
thank you. i was hoping to avoid that but oh well thanks for the info
Old Jul 28, 2012 | 09:59 AM
  #56
LILHEMI's Avatar
is this the adaptor your talking about?
http://www.jegs.com/i/JEGS-Performan...rentProductId=
Old Jul 29, 2012 | 09:31 AM
  #57
Stu Cool's Avatar
I used one of these from Jags That Run http://www.jagsthatrun.com/Pages/Par...r_Reducer.html
Old Jul 29, 2012 | 10:26 AM
  #58
LS1Tech Co-Founder
I'm on the North side of Chicago 312 371 5812 cell if you need anything.
Old Jul 30, 2012 | 09:13 PM
  #59
Stu Cool's Avatar
Thanks John, made it to South Bend just fine. Driving across the South side near Joliet those posted speed limits appear to be be just a suggestion! Driving a bright red car with out of state plates I have been trying to stay close to speed limits, but along there doing so was just plain dangerous!
Pat
Old Aug 20, 2012 | 07:23 PM
  #60
Stu Cool's Avatar
I talked with the Griffin folks at Hot August Nights. They have a very nice LS conversion radiator, but unfortunately it is a couple inches too wide. When I got home, I called them up and based on their recommendation I have ordered an aluminum down flow radiator that will bolt in and even look pretty much like the Studebaker radiator. It has 2 rows of 1.25 tubes that will more than double the capacity of my previous copper/brass radiator. It will be configured for LS hoses and will have the top connector on the passenger side, just like I need it. It will have the rad cap above the motor which the cross flow does not and I was told that will also make a difference. It will also have a trans cooler in the bottom tank that I never have had. So, I am anxiously waiting for that to arrive in a couple weeks. I will update with pictures once it arrives.
Pat
