57k miles 5.3 complete for $1,200
#83
Merims123
Im thinking of dual springs even if I plan on running the z06 cam.
Couple of questions, what type of pushrods will I need. I've been doing a lot of reading and people say stock is fine.
Another question
I'm a bit confused as to open the ring gap or not. Skinnes suggested in his thread stock was fine. And then I find this from sinisters thread.
![](http://i1182.photobucket.com/albums/x445/alexcoreas1987/2012-04-12200349.png)
Sorry guys im just trying to do a lot of reading and educate myself on this as it is my first build.
I know a dead on tune is key and I'm more then confident cms can take care of me.
Any information is appreciated
Another question
#90
Ill call to make sure.
So far things I have ordered are the ls6 valve springs.
Z06 cam (eBay)
Stock MLS head gaskets
arp head bolts (are they all the same?)
I'm still looking for a complete ls1 oil pan
water pump
alternator
and crank pulley.
Truck manifolds
Finding things local or within 80 miles is hard.
Z06 cam (eBay)
water pump
alternator
and crank pulley.
Truck manifolds
#91
arp head bolts are not the same. the 04+ blocks are different than 03 and earlier (so you have to order for your block)
i know it's expensive, but you can get a new pan kit for 300-330 form a chevy dealership. check in with sdpc the sponsor here. what are you doing for steering?
#92
Ill be getting 02 arp bolts then.
For steering I'm going with a manual rack and pinion from these guys
http://shop.rackdoctor.net/CAMARO_c40.htm
I'm trying to get this thing as light as possible. I'm taking it to the scale tomorrow. They just opened a public scale close by.
Ill check scdc for an oil pan. If not ill check the dealer its a block away but they are so expensive.
#98
Where are you located? If you don't mind
The 216/216 will cost me $175
A lot of threads are making me lean towards the single pattern on a small 4.8 but there are to many variables, one being my bottom end is stock.
Thanks for replying guys
