Very Oddball Conversion
Old Mar 27, 2012 | 01:04 AM
need2speed94's Avatar
Default Very Oddball Conversion
I have no intentions/plans/funds/etc. to do this Anytime soon, but hey, what's the harm in dreaming or thinking? Has anyone ever swapped a Cummins into a 4th Gen F Body? I've always liked diesel's, particularly the Cummins... but Dodge trucks are POS's I'd like to have something one of a kind, and Cummins powered 4th Gen would do just the trick. So, is it possible/has it been done before? If it is possible and I could actually commit to this someday, I'd try to stay away from a 4bt because IMO they sound like complete ****.
Old Mar 27, 2012 | 01:56 AM
Jameslt1TA's Avatar
Youtube diesel camaro. I remember a 6.5 diesel 4thgen, Ill bet there is a cummins one out there somewhere.
Old Mar 27, 2012 | 02:12 AM
Yeah I saw that one, I'm mostly interested in a 4th gen Cummins swap... Can't seem to find that. Also, that 6.5 diesel powered camaro had a rear mount turbo... just to add to the complexity of a diesel swap a god damn rear mount turbo, no thanks lol.
Old Mar 27, 2012 | 06:25 PM
dogger's Avatar
I'll bet there's no 6bt in a fourth gen those motors are just huge and heavy. I could see a duramax swap but not a Cummins that would be pointless
Old Mar 27, 2012 | 06:33 PM
ALL diesels are huge and heavy, the Powerstrokes (EWW) and Dmax's are the heaviest and widest, but the Cummins would be the longest. What's wrong with a Cummins? Definitely show more durability in terms of the internals and they hang with the powerjokes and dmaxs while they're down 2 cylinders? Pretty good if you ask me, it's the POS truck chassis they come in
Old Mar 27, 2012 | 07:53 PM
wfritts911's Avatar
Cummins makes a 4BT that they put in Frito Lays vans and the like. 3.9L, 4 Cylinder, turbo. We actually swapped one into my brothers '90 Bronco two summers ago. Great little motor, doesnt take but 2 wires to run, is rated with more torque than his 351W was factory, and gets close to 30MPG. That would probably fit in an F-Body if it wasn't too tall, but you definitely won't be losing any weight, that is one heavy 4 banger.
-Will
Old Mar 27, 2012 | 08:06 PM
-Will
I mentioned that I want to stay away from the 4bt... I think they sound like **** lol.
Old Mar 27, 2012 | 11:44 PM
2baditsnotachev's Avatar
As long as you don't mine most of the engine sticking through the hood it would be cool.
Old Mar 28, 2012 | 10:33 AM
STEEPSS's Avatar
I've seen a duramax in a 69 camaro before. pretty ballin.
edit: found vid
Old Mar 28, 2012 | 05:45 PM
Like I said this swap won't happen for awhile if not ever.... and given I actually have the funds to commit to it, I'm sure I could afford a bigger hood Or I could be a cool guy and run no hood lol
edit: found vid
Yeah I see plenty of diesel swapped 1st gens, the engine bays of 50s/60s/70s cars were much much bigger since they all had big blocks as options. Not to mention compared to a LOT of cars, the 4th gen engine bay isn't exactly idea for big blocks or anything larger than an LTx/LSx or something LT/LS based.
Old Mar 28, 2012 | 07:20 PM
alexcoreas's Avatar
Are you just trying to bug people dude.
First you say you have no funds and then you say " actually I have all the funds to commit to it"
Make up your mind
Old Mar 28, 2012 | 07:26 PM
Conrad's Avatar
Make up your mind
Are you trying to bug people with stupidity?
Old Mar 28, 2012 | 07:56 PM
broke again's Avatar
i wish i could find these 50s/60s/70s cars with the much, much bigger engine bays. everyone i have worked/swapped had shock towers and have very small engine bays as compared to fox mustangs and the like. good luck but you really need to check out how tall a 6bt cummins really is....
Old Mar 28, 2012 | 08:03 PM
raven_450's Avatar
There was a guy who swapped a dmax into a 95ish mustang I'd assume that same swap could be done on a 4th gen. I doubt a cummins would work I mean with enough money anything can.
Old Mar 28, 2012 | 08:07 PM
raven_450's Avatar
http://www.dieselpowermag.com/featur...x/viewall.html
Old Mar 28, 2012 | 08:35 PM
Haggar's Avatar
I believe the Cummins are heaviest. 12v 5.9s are around 1000lb, 24v's are over 1100lbs. And they are over 3ft long and over 3ft tall.
Duramaxs are more like 825-850lbs.
Old Mar 28, 2012 | 08:54 PM
Make up your mind
Read it ***carefully "given I actually have the funds" in an elementary school explanation means: "if somehow I could actually have that kind of money"
Old Mar 28, 2012 | 08:55 PM
Those are the best cars for the hobby! Pre-smog and you have such a wide variety of motors to choose from to swap, the engine bays were crazy large.
Old Mar 28, 2012 | 08:59 PM
Really? I mean thinking about it without knowing the specs, you'd think the I6 with just one head and 2 less pistons/rods/etc. would weigh less... maybe the extra weight is just the bulletproof components that give Cummins a good rep yeah I've seen how tall and long they are, the height is particularly weird, how long they are is just another typical I6. I knew the dmax's are the lightest though, they have the aluminum heads that people like to talk **** about haha.
Old Mar 28, 2012 | 09:01 PM
So your just a complete bullshitter is what your saying ...
