Went to start, Melting C101 pin H (ground)
Old 03-29-2012, 12:13 PM
crashnscar's Avatar
Default Went to start, Melting C101 pin H (ground)
Went to start my swap today and it cranks but won't fire. I tried starting it last night as well, but noticed I had forgotten to run battery cable to the starter and alternator. Did the starter (but not alternator yet) and the car cranks over but wont fire.
99 LS1 from Camaro
HP Tuners to delete VATS
Additionally, when I try to crank it, pin H on C101 starts smoking/melting. I have it grounded to the chassis on the same stud as a few other grounds.
What did I do?
Old 03-29-2012, 12:34 PM
Pop N Wood's Avatar
How do you have your battery connected to the motor? I assume a large black cable bolted straight to the block? A second wire from the negative terminal to the chassis? What other grounds do you have, i.e. motor to chassis and harness to chassis etc?
Sure sounds to me like you don't have proper grounds so your car is trying to do something like run the starter current through the ECM ground. Obviously not good.
Old 03-29-2012, 01:27 PM
crashnscar's Avatar
Yes, went back out and started testing stuff. Found the chassis had +12v! :-o
Hopefully nothing was damaged. I improved the grounding and got rid of that voltage in the chassis. Now it cranks but won't fire. I'm using a tiny battery and this diagnosis is probably taking its toll on the battery so I'm going to try again with jumper cables to another battery. Any other ideas on why it wouldn't fire? I definitely have fuel pressure, next I'll check spark if jumping with another battery doesn't work. I don't own noid lights so can't really check injectors.
Old 03-29-2012, 05:09 PM
crashnscar's Avatar
Still doesnt start, but definitely tries to.
Just bought noid lights, injectors are firing. Spark is also firing. What now?
Possibly not a large enough wire running to the coils/injectors?
Old 03-29-2012, 05:56 PM
ls1_chevelle's Avatar
confirm fuel pressure at rail?
How did you confirm spark?
My car wouldn't fire. Had everything as if it would/should fire. Plugs would spark outside of the cylinder but they were too fouled to fire under fuel and compression. New plugs and it started.
Old 03-29-2012, 09:13 PM
crashnscar's Avatar
There is definitely pressure, but I haven't hooked a gauge to it to know how much.
Confirmed spark with a plug out of cylinder. All plugs and wires on motor are brand new.
Old 04-01-2012, 12:27 PM
are the plugs getting wet? is it a DBW setup? if so does the TB respond to pedal input?
Old 04-19-2012, 07:58 PM
crashnscar's Avatar
Drive by cable setup. Plugs are definitely getting wet. See attached photo of plug... these were brand new before I started firing this swap.
Tried to take a log of cranking using HP Tuners VCM Scanner. I'm getting nothing at all for Cam Hi Lo or Cam Lo Hi. I went into scanner chart settings, changed two of the chart variables by selecting Cam Hi Lo / Lo Hi after clicking on PID. Am I doing something wrong? Anything you can tell from the attached log file?
Attached Thumbnails Went to start, Melting C101 pin H (ground)-photo-689.jpg
File Type: hpl
Old 04-19-2012, 08:23 PM
rotor vs. piston's Avatar
Cam sensor unplugged or damaged?
Old 04-19-2012, 08:35 PM
crashnscar's Avatar
Not unplugged.
My understanding is that the engine will still fire without the cam sensor, just will be a little harder as the PCM will try firing and if that doesnt work then it will try 180* from where it tried unsuccessfully.
Quick Reply: Went to start, Melting C101 pin H (ground)
