Couple of water pump questions: thermostat housing & converting to AN outlets
I am in the home stretch of my conversion 69 Camaro/LS2 conversion. I still need to order a thermostat housing and the clearance on the heater hoses connections on the water pump are less than desirable.
I will be re-using my existing radiator and it has a 1 3/4" diameter opening. Should I use a straight or a swivel setup from Street & Performance? Are there other options?
For the heater hoses I am thinking about removing the pressing connections and converting to AN fittings. For those that have done it do you have any recommendations whether I should use straight, 45s or 90 degree adapters? Thanks in advance.
