4.8 cuts out under hard acceleration
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I'm not familiar with the ASD relay in a Jeep, you would have to get a Jeep service manual and some schematics to see if it would be possible. I have used an inertia switch from a Ford, the kind with the red reset button on top, that trips under impact. It's probably the easiest one to use since it just goes in line between the relay and the pump. I know it works because when I was building the car I bumped it hard enough to trip it, then spent about a half hour trying to figure out why the fuel pump wasn't coming on the next time I tried to start it! Doh! ![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I will check at the salvage yard tomorrow , Im going after some heat shielding and another AC line . Trying to get the AC working the Chevy Jeep Clone AC is fighting me. I almost had it but the custom hose failed. :-(
I'm not sure what a Mustang would have, but it's probably the same. Mine came off an late 80's-early 90's LTD. Explorers around 2000 have a similar one as well, and have an extra wire that goes to a light on the dash that comes on when tripped, and I'm pretty sure you could just wire it to any kind of light bulb.
Sorry to hear about your A/C line. How did it fail?
I'll prob have to pull the comp again just to get it off. I knew something was up being I couldn't pull as good a vac as I usually can, and when I was charging the low side would fall fast to 0 as the high side was reaching 100 psi. Im sure it was just a bad hose, it was were the metal line was crimped onto the hose, and not the new end. I thought about changing to the denso adapter and go with a generic hose like I did on the suction side. I called the adapter place and they are out of those adapters for an unknown time. So I guess Im back to modding a OEM hose.
What year is engine? Assuming stock EFI?
Im not really an expert but,
IMO first do a pressure test, that will tell you if its really a poor flow issue. (It could be electronic issue) It sucks to fix the wrong stuff.
Let us know
Let us know
![](http://i620.photobucket.com/albums/tt281/nankipoot/IMG_20130722_152552_128_zps2bd6f7e4.jpg)
But something else,,,, if its a fuel starve issue should it do it also in park?? I can press the pedal to the floor and it will rev up fine and holds at a high rpm (I dont hold it long but it feels like it would stay high as long as I held the gas)
Ideas?
Thanks
#35
bellow are old pics of orriginal install
here is a pic of the tube bottom right
![](http://i620.photobucket.com/albums/tt281/nankipoot/2011-12-18_16-00-06_241.jpg)
tube on pump
![](http://i620.photobucket.com/albums/tt281/nankipoot/2011-12-19_11-01-47_674.jpg)
Any ideas
#36
Read this thread, post #22, this is what I would use. https://ls1tech.com/forums/conversio...culptit-2.html The ethanol in gas these days will kill a rubber hose in a gas tank, I just had it happen, luckily the car made it home and my pump is easy to get out.
#37
I took the GM pump out and did away with the sliding tube on top of the pump and just ran the rubber hose with clamp to eliminate possible leak down location. and still falls to 0 psi very fast. So Id rather it start good and still have WOT thing til I just build another pump assembly. So I put the oem TJ pump back in . It starts better than the GM pump but not as good as before I swapped it. So the fuel line tube must not be seating correctly is only thing Im thinking on it. Im thinking Ill just go ahead and build a separate complete swap pump assembly using a spare top housing. The only thing is I would like to do away with the can that surrounds the pump but Im unsure what affect that would have. Do you know what that can around the pump really does? I know even in the OEM the fuel return dumped right in the can. The mod version I did dumps it in there as well. I figured its a way to keep the fuel supplied to the pump if low and on a hill or something, or maybe a keep the pump cool thing IDK. But if I could do away with it then the pump filter and connections would be way easier to get to.
here is a link to the OEM assembly to see the can Im working with. I removed the regulator at the top and ran a return that dumps into the top of the can. Behind the corvette filter
http://www.ebay.com/itm/New-Fuel-Pump-Gas-With-Sending-Unit-Jeep-Wrangler-TJ-2002-2001-2000-99-98-97-/370838761312?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1997%7CModel%3AWrangler&hash=item5657b66f60&vxp=mtr
