S10 Xtreme L33 swap!
The engine I got had a knock sensor that was rotted badly because of water intrusion. Was a bitch to get out, but luckily no permanent damage to any of the motor. Just had a little corrosion to clean up and a new sensor to buy.
James
James
Small update...went to the junkyard the other day and grabbed some small stuff, couple bolts, radiator cap, upper radiator hose from a 5.3 silverado (for test fitting), and the brake booster nipple that was broken on my intake. Also pulled some threaded inserts out of an intake for my intake manifold since the L33's came DBW and I'm going DBC.
Got my 98-99 F-Body manifolds I bought off of blackphantom (excellent seller by the way, very fast shipping!)
![](http://i1185.photobucket.com/albums/z343/zdiesel123/2012-05-26_12-42-35_204.jpg)
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Needed the 98-99 style manifold to cut the flange off and weld a tube on since the flange would hit the frame rail, and the 00-02 style are cast iron I believe, makes them harder to weld to supposedly. Thanks though! Up in winterport huh? I'll probably try and make it to winterport dragway when I head back up that way in the fall for school if it's still open.
No more updates as of yet. New AC compressor is in the mail since the one that came with the pullout was damaged. I've also done some rationalizing and realized I can afford a T56 just yet, so I picked up another 4L60e. Will post pics of that later tonight I suppose, nothing special. Stock 4L60e out of an 04 5.3 Silverado with 30k on it. Corvetter servo is also in the mail. Wiring harness is 6 weeks out, and I start work in a week here so the money will start pouring in as will the parts!
No one picked up on that apparently.
This morning I turned this...
![Name: 2012-06-27_07-12-05_307.jpg
Size: 167.0 KB](https://ls1tech.com/forums/attachments/conversions-swaps/676293d1501791986-s10-xtreme-l33-swap-2012-06-27_07-12-05_307.jpg)
Into this...
![Name: 2012-06-27_16-07-59_419.jpg
Size: 132.2 KB](https://ls1tech.com/forums/attachments/conversions-swaps/676294d1501791986-s10-xtreme-l33-swap-2012-06-27_16-07-59_419.jpg)
M12 out of an 04 GTO with 45k miles on it, complete with an f-body hurst shifter, flywheel, clutch, all hydraulics, and starter. Thank god I don't have to run an auto haha
Into this...
#33
I checked out the two throttle bodies and the intake manifold and I can't see where a vacuum leak might occur, so I think it should be fine as is...
DBW TB:
![Name: 2012-05-29_20-18-26_426.jpg
Size: 72.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/676295d1501791986-s10-xtreme-l33-swap-2012-05-29_20-18-26_426.jpg)
DBC TB:
![Name: 2012-05-29_20-18-19_647.jpg
Size: 74.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/676296d1501791986-s10-xtreme-l33-swap-2012-05-29_20-18-19_647.jpg)
Intake and two TB's:
![Name: 2012-05-29_20-18-08_762.jpg
Size: 89.0 KB](https://ls1tech.com/forums/attachments/conversions-swaps/676297d1501791986-s10-xtreme-l33-swap-2012-05-29_20-18-08_762.jpg)
Am I missing something? I don't see where a vacuum leak would occur.
DBW TB:
DBC TB:
#34
I did the opposite, put a DBW on an LS1 intake and the ports are a little different. Your set up doesn't look like you will have that problem.
#37
Its coming along, the worst part about the stage your (and me) at is having to look at all these cool parts you bought and not being able to put them in. Looks good, you"ll have to check out my swap thread too.
#38
It really is though haha, I may or may have not been sitting on the floor of the shop the other day pretending I was driving it while shifting the T56.
I'm only 20...20 year olds still play imaginary race car right?...right?![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
Either way, I'm glad other's find my thread useful. Paying off some loans, parts should start flying through the door in a few weeks first of which my oil pan so i can pull the 2.2 and get this L33 fitted in the truck. I'll have to pick up some steel for my notches.
