Low mount alternator
Old Apr 30, 2012 | 09:43 PM
dmracing's Avatar
Default Low mount alternator
Alternator and water pump only. how did you do it?
Old Apr 30, 2012 | 09:54 PM
i r teh noobz's Avatar
How low? I'm using an F-body alternator bracket with no idler.
Old Apr 30, 2012 | 10:01 PM
dmracing's Avatar
Will it work with an iron block?
Old Apr 30, 2012 | 11:16 PM
-TheBandit-'s Avatar
You have to drill and tap a hole that normally isn't there on the iron block. It's no big deal though. Not sure what the belt routing looks like for that setup tough.
Old Apr 30, 2012 | 11:28 PM
FastKat's Avatar
This is how you do it using an F-body alternator bracket. (Not my car.) It will also work with a G8 alternator bracket. The F-body and G8 brackets are essentially the same with different accessory spacing. (F-body belt and accessories are farther from the engine, G8 belt and accessories are closer to the engine.)
Old May 17, 2012 | 09:31 PM
2JZFC's Avatar
Does anyone know what belt this setup uses? Part # or length?
TIA
Old May 18, 2012 | 10:34 PM
FastKat's Avatar
FWIW, last week I saw someone use a Corvette crank pulley and a G8 alternator run an A/C belt between the two. It eliminated the need for the tensioner.
