problems with swap harness and 411 pcm
Old May 1, 2012 | 03:52 PM
1972nova's Avatar
Default problems with swap harness and 411 pcm
Ok so I got the nova to start and working through a SD tune with the Tuner. we have issues with both bank 1 and 2 front o2 sensors
With the key on engine running the sensors are not responding they are at the default .450ish number and as soon as you back the key to the off position and the data logger stops logging it shows the o2's respond and they show values.
A little run down
Techrods 5.3 truck harness cable drive
0411 pcm
370" LSx 4788 turbo
brand new bosch 4 wire 02 sensors
no faults for 02 sensors at all
I have an email into techrods but have not heard back yet
Just looking for some help
Old May 1, 2012 | 04:43 PM
1972nova's Avatar
harness wires are
A- TAN
B- Purple
C- Black
D- Pink
leading into a bosch 13193 o2 sensor 4 wire translates on the o2 wiring side
a-grey
b-black
c- white
d-white
Old May 1, 2012 | 04:53 PM
1972nova's Avatar
could the 13193 sensors be the wrong ones for my car? they are 4 wire just seems odd that both are brand new and not responding
Old May 1, 2012 | 04:54 PM
aknovaman's Avatar
Chk for power to the o2 sensor heater wires. Likely you don't have +12 volts between the pink and black wires.
Old May 1, 2012 | 04:57 PM
1972nova's Avatar
pink and black 12v key on
Old May 1, 2012 | 04:58 PM
1972nova's Avatar
just weird how can I find out what wires are on the 02 sensor? am I safe to say that the black from the engine harness should goto a black wire terminal on the 02 sensor because it goes to gray
Old May 1, 2012 | 05:46 PM
aknovaman's Avatar
Heater power and ground are interchangeable. O2 signal high and low are not.
Old May 1, 2012 | 05:57 PM
1972nova's Avatar
well do you know how it should be wire on the o2 side?
from harness
A- tan 5v key on and key on running
B- Purple 5v key on and key on running
C- Black Ground
D- Pink 12v
I post above but its currently wired
Tan-Grey
Purple-Black
Black- White
Pink-white
Seems it has to be an o2 issue these are brand new but of the options wonder if I should of had 13444 or 13474
1972nova's Avatar
double post
Old May 1, 2012 | 06:47 PM
1972nova's Avatar
so pretty much my bet is going to be either faulty 02 sensors (both) which would only mean to me that the sensors are not correct for my app
or
faulty ecm
Old May 1, 2012 | 07:13 PM
1972nova's Avatar
should both tan/purple wires be seeing 5v. I thought the sensors operate 0-1v
Old May 2, 2012 | 08:00 AM
psiconversion's Avatar
LS1Tech Sponsor
Can you read the pinout on the engine harness? The connectors should be labeled A through D. If not, post a picture. We should check the pinout.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old May 3, 2012 | 01:27 PM
1972nova's Avatar
**UPDATE**
PROBLEM SOLVED. In case someone else runs into this and cant figure it out like it took me forever to do.
Depending on your year of pcm and wiring harness GM used two different types of 02 sensors. Case grounded and Isolated ground, Comparing the 2 truck wiring diagrams and an fbody 411 pcm diagrams I checked the wiring and see what wire for the o2s went to what pins on the C1 blue ECM connector.
It matched the diagram for needing a sensor for case grounding
For my situation I was using a brand new bosch 13193 sensor which had a white connector. From what I reasearched the white connector was an o2 for isolated grounding sensor. My PCM was looking for a case ground to complete the circuit and I needed either an fbody sensor or a truck sensor with the black square 4 pin harness.
Went to Jegs down the street and picked up two bosch 13474 sensors for 28.99 each and fired it up and the logger immediately started reading voltage.
Old May 3, 2012 | 01:42 PM
bczee's Avatar
Great going there !... This is why it is important to know what your using and what it came out of. Mix and Matching can lead to a lot of head banging !...
Old May 4, 2012 | 07:06 AM
LS1Tech Sponsor
Yes, the white connectors have PWM heaters in them which go back to the PCM on a BLUE/GREEN. Question, how did you even get them to fit your harenss, they arent keyed correctly.
Jon
PSI
__________________
Ebay Store
Old Jun 24, 2012 | 01:42 PM
04BlackGmc's Avatar
Good info here.
I ran into a issue just recently with the GF's car trying to find the correct o2s for it. After looking at her harness(i can't remember the place who made it it's a Full LS1 computer and harness made for swap cars) and it has the black 4 pin square connectors looks like ill be needing the 13474 truck o2s.
Old Jul 1, 2012 | 07:02 PM
1972nova's Avatar
yeah glad to post as much info on here as possible. I know ive used this site to answer many questions
Old Jul 1, 2012 | 11:03 PM
bczee's Avatar
Glad you figured it out... and shared the info.. thanks..
BC
Old Dec 11, 2012 | 10:43 PM
Bilster's Avatar
This thread saved my bacon!!! My only concern is the Bosch 13474 for LS trucks is listed as a downstream application. But the male pin-outs with the one block out connection is the only one that will work with my stand alone conversion harness. My harness connection is like what's pictured. That doesn't match the O2 sensor that is called out for my 2000 5.3 application which is the Bosch 13193. I was pulling my hair out trying to find the proper pin-outs.
Attached Thumbnails problems with swap harness and 411 pcm-o2-sensor-connection.jpg
