How LOW can an Ls1 get?
This one is an LS7 with a dry sump.
Thanks!
Where can I get this scoop from??
Regarding oil pans, I've used C5 batwing and C6 pans without any problems. The bottom of both pans ends up around an inch higher than the bottom most part of the cross member. I have more issues with the exhaust hitting stuff than anything else (mostly the U-bolt connecting the mufflers to my turn downs.
Thanks!
I have a 1977, the ls fits nicely under the hood, i have plans made to us the factory fuel rail mounting holes and using metal rods to mount the factory shaker to, this method still holds the fuel rails in place with no modifications. The extended rods is where it will mount to the shaker scoop and running my own made air box under the shaker, simular to the photo above
