How LOW can an Ls1 get?
This one is an LS7 with a dry sump.
Thanks!
That shaker "intake" with the snorkel going down to the throttle body is really impressive. Think that's available aftermarket or is it a 1-off custom piece?
I'll bet if you ran a carb you could hook it into that shaker intake. It would unquestionably be a lot less restrictive by removing all those bends. Or to stay EFI something like a fast EFI or MSD atomic on a carb intake.
I really don't want to dry sump just because of the cost.
*edit, found it*
Goldberg's wifes TA, which i believe has an LS7 in it. Retained the shaker, while making it look pretty dam nice.
http://www.pro-touring.com/showthrea...ion-2.0/page16
I'll get reading.
Wonder how the GTO front frame compares to my trans am....
Also, if that is the Year One car, I don't think it has an LS7 oil pan. Actually, it looks like it has a deep sump wet sump pan that is very tall in the back. Check out the third to last build pic on the first page:
http://ghostworks.yearone.com/bandit...s?show=gallery
I don't see an oil tank under the hood anywhere, either. There's canister against the passenger firewall, but it looks like more of an Accusump-type device if anything.
I built this Cowl Induction system back in late 05' or early 06'.. before Year one started there 69 Camaro and TA Hoods.. The Cowl Induction is fully functional as it would be stock.
BC
