Project Twin Turbo 83 S10
#121
#123
More pictures!
![Name: 2012-08-31200715.jpg
Size: 48.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612175d1501331516-project-twin-turbo-83-s10-2012-08-31200715.jpg)
![Name: 2012-08-31200731.jpg
Size: 52.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612176d1501331516-project-twin-turbo-83-s10-2012-08-31200731.jpg)
Here's how the interior sits...havent worked on it much lately
![Name: 2012-08-31201112.jpg
Size: 35.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612177d1501331516-project-twin-turbo-83-s10-2012-08-31201112.jpg)
![Name: 2012-08-31201851.jpg
Size: 32.6 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612178d1501331516-project-twin-turbo-83-s10-2012-08-31201851.jpg)
Picked up a few goodies from Summit
![Name: 2012-08-31192810.jpg
Size: 42.2 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612179d1501331516-project-twin-turbo-83-s10-2012-08-31192810.jpg)
Holley Dominator fuel pump w/filters
![Name: 2012-08-31193057.jpg
Size: 39.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612180d1501331516-project-twin-turbo-83-s10-2012-08-31193057.jpg)
Made a mounting plate for the fuel and I/C water pump
![Name: 2012-09-01140449.jpg
Size: 42.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612181d1501331516-project-twin-turbo-83-s10-2012-09-01140449.jpg)
![Name: 2012-09-01161646.jpg
Size: 52.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612182d1501331516-project-twin-turbo-83-s10-2012-09-01161646.jpg)
![Name: 2012-09-01163913.jpg
Size: 20.1 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612183d1501331516-project-twin-turbo-83-s10-2012-09-01163913.jpg)
![Name: 2012-09-01180044.jpg
Size: 35.1 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612184d1501331516-project-twin-turbo-83-s10-2012-09-01180044.jpg)
![Name: 2012-09-01180105.jpg
Size: 30.2 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612185d1501331516-project-twin-turbo-83-s10-2012-09-01180105.jpg)
#124
just read the whole build-very nice
what are you doing for the rear diff? 8.8?
Someone posted that the two pc camaro manifolds don't work with a turbo.
They go to pcs I'd guess. The LS3 manifolds may fit flipped with slight angle mill. Call SpeedInc and ask. Intimd8 has some on his TT chevelle.
Also, Hooker has some new cast manifolds. No one has tried them yet.
#125
I'm planning on using an 8.8/4-link/coilover combo for the rear. Its a little late to change my manifolds at this point. If the Camaro one comes apart ill just have to redo that side. The truck will be taken apart again late winter for a rebuild and a new tranny so ill be able to make any changes that are necessary then. Most of this stage is just getting everything to fit and work properly.
#128
Thanks for all the kind words guys. I'm so anxious to start it you don't even know. I just need my other heat exchanger for the front with a bunch more fittings,my trans cooler, injectors and misc sensors and I can finally turn the key.
#129
Got a few more things knocked out...reinstalled the hood finally. Its been months lol.
![Name: 2012-09-02174347.jpg
Size: 61.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612142d1501331446-project-twin-turbo-83-s10-2012-09-02174347.jpg)
Also finished up running all of the hard lines for the fuel and intercoolers.
![Name: 2012-09-02185508.jpg
Size: 34.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612143d1501331446-project-twin-turbo-83-s10-2012-09-02185508.jpg)
![Name: 2012-09-02194631.jpg
Size: 39.8 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612144d1501331446-project-twin-turbo-83-s10-2012-09-02194631.jpg)
#135
#137
Hopefully ill be able to shoot some videos of it running within a couple weeks. Unless y'all want videos of it just sitting there haha. I may be able to get Sarg to make engine noises!
#139
Not really sure yet. I do know that I will have two sets. The street set will be polished 17", maybe 17x7 front and 17x10 rear. The drag set will most likely be black 15" steelies with skinnies up front
