ls376 into 95 camaro
search function does wonders.
The reason people "Twin Charge" their cars is usually to help the Turbo Spool up faster. The S/C builds up boost much faster than a Turbo does and this gets rid of "Turbo Lag" (Turbo Lag is the wait time your car has before the engine actually begins benefiting from the power of the Turbo)...However once the Turbo actually builds up enough pressure then the S/C isn't really doing too much more. It would be easier to setup a twin turbo system. A small and large turbo. Also I don't think you will likely need N20 to assist you in a F.I. LSX motor... you will be going MORE than fast enough, trust me. I say money spent in beefing up the trans and rear end...
As far as meth goes, unless you're running some SERIOUS boost and looking for somewhere over 800 HP, I don't think its necessary either. You would be better by learning how to tune it and buying a sufficient inter cooler.
Don't just throw parts at cars and assume that it's faster. Thats not how engines work, every part works in synchronization with the rest of the engine but another part can throw off that synchronization and make for a poorly tuned setup.
As far as hardware necessary, I highly HIGHLY recommend staying away from digital gauges in fast cars. You want to be able to SEE your RPM range for diagnosing and other things. They look cool but I think the standard stuff is more functional.
For wiring and computer, you're going to need a 98 F-Body car wiring harness and computer from an LS1. 99 - 02 will not work, nor will anything before 98.
Then the standard stuff as far as hardware goes.
-K-Member
-V8 Suspension (Springs, Struts, Sway Bars)
-If your crate motor comes with Truck style accessories, you can use them by relocating the alternator to the passenger side where the tension is and using a half inch spacer. Move the tension to the position of the alternator. If not just buy F-Body accessories.
-Car Intake. I'm assuming LS3 or L76 in this case. (assuming your crate motor comes with a truck intake, if not then you're fine)
-12 Bolt Rear Axel - I'm not even ganna try to recommend a Z28 rear, you're ganna need this to sustain the power you're trying to put out.
Those are the real main things. It's not VERY hard, there's ganna be alot of little things but this for the most part is it.
-K-Member
You need the ECU and Harness out of a 98 F-Body LS1.
I'd contact merv regarding making it functional.
Regarding the engine, while that IS an awsome engine don't get me wrong but have you considered grabbing a used LQ4 with like 100k on it for about $1,000 and then 408 strokering it along with a rebuild? It may come out slightly cheaper and you will have more displacement if you can do all the work.
