LS Crown Vic?
It gets more complicated when they switched body styles in the late 90's. All the data is then shared over the network and all the engine sensors feed the PCM, which then shares that data over the network to the cluster.
Although i've not tried this method, it has been mentioned that you could leave the stock Ford ECU in place, and powered up. Then, use the Ford senders on the LS motor like you would do on an oder Vic. This way the Ford ECU keeps the cluster happy by sending the insturment data to the cluster. Odometer and other functions should be maintained as well this way, however you'd have to find a workaround for the MIL and some other issues i'm sure, but it's doable.
Need to order the adapter fittings for the truck Denso A/C compressor and fab the lines yet, get some radiator hoses and do a little wiring then we getting closer to firing!
The electrical side is a little more tricky depending on which year of PCM you use as they went from a hardwired input to the PCM for A/C request to a network request in '03. On one of my other builds we had to do a pretty elaborate work around for the network issue, but functions normally now.
Got some wiring, ac hoses, master cylinder wrap, turbo air filter and a few othe small things left, but should be running by end of month.
Here's a little video tour of the progress:
http://www.youtube.com/watch?v=DHznW...ature=youtu.be
I don't expect her to play much lower than the 11's to be honest, but I could be suprised. I only plan on 15psi on the stock 6.0L. My 5.3L made 550 RWHP on 10psi with a stupid safe tune, however this pig should come in around 4200lbs with a driver.
All in good fun, it should suprise a few lightly modded Camaro's and Mustangs.
Getting there!
6.0L (LQ4), 76MM Turbo, 4L80E.
My last turbo build:
https://ls1tech.com/forums/conversio...5-3-mpt70.html
Being told by a local LSx swap shop that without that crank / cam input, the Ford ECU won't output anything useful - ie, it won't read the voltage fluctuations off the sensors mounted in the LS motor and output those to the cluster.
Thoughts?
