LS Crown Vic?
Old Aug 8, 2021 | 08:11 AM
  #41
Michael Yount's Avatar
Originally Posted by 64post
Would have never guessed a Crown Vic or Marauder weighed so much.
Pretty sure all the the VIN’s have “USS” in them somewhere.
I always like seeing something different out there, and this qualifies.
Old Aug 9, 2021 | 10:11 AM
  #42
LQ4-E39's Avatar
I swapped an '11 Crown Vic PI with a 6.0/80E and the stock express computer/harness. You can use the GM PCM to drive the older (analog) Ford clusters (I'm using a Marauder unit). I didn't bother trying to crack the newer CANBUS cluster.
Car will be for sale soon, build thread is in conversions/hybrids section under my name.
Old Aug 9, 2021 | 11:51 AM
  #43
ryeguy2006a's Avatar
I wonder how difficult it would be to have Holley create an output that would feed into the Ford ECU for Crank/Cam signals?
Old Oct 7, 2021 | 04:10 PM
  #44
ledzepp3's Avatar
A bit both on and off topic to this resurrected thread, but I've got my GTO's original T56 that was pulled when I did my Mangum F swap. A friend who's gathering parts for an LSA 5.3 2010 Vic build wants to use my T56 in it, but we weren't sure and couldn't find a lot of documentation on which variation of the T56 guys were using. Anyone have any experience, insight or recommendations for him?
Old Oct 11, 2021 | 08:05 AM
  #45
LQ4-E39's Avatar
Guys have manual swapped Crown Vics before using the original Ford motors so it's not impossible to install a manual trans. I believe they used the 4.6 Mustang 5 speed parts (pedals, etc); As long as it's a hydraulic system I don't see why you couldn't use that to actuate the T56 slave. Then it's just a matter of cutting a hole in the floor.
