Difference in low/full markings on GM LS2 Transmission dipstick
Getting ready to install the trans dipstick and tube. I am comparing the original TBSS tube/indicator to the new LS2 tube/indicator (GM # 92159815 out of 2006 Pontiac GTO) and noticed there is a big difference in how far the indicator protrudes into the pan. The black tube is out of the TBSS and the other is the new tube. The low/full indicator markings protrude a lot deeper into the pan than the new one (see pic below). Anyone have any thoughts on this?
I think I am just going to use the new indicator and cut down the TBSS tube until the low/full marks stick match the TBSS.
Not the best pic, the black tube is the TBSS, the other one is the new GM tube
![](http://i204.photobucket.com/albums/bb62/RocketRod1967/69%20Camaro/LS2_4l70e_Swap/Miscellaneous/IMG_2922c.jpg)
No, just the dipstick tube and indicator. The tubes protrude the same distance into the pan, but the low/high marks on the indicators are different. I put this out here more for people to be aware when they change the dipstick/indicator to compare it the the old one before doing so.
I ended up using the new indicator and cutting down the TBSS tube so the low/high marks are in the same location as the TBSS dispstick.
