Third Gen Camaro LQ4 Swap
. Well here I am 5 years later just having graduated college and I have finally started amassing parts to bring the old Z28 back to life. I have just purchased a complete lift out 6.0 LQ4 (engine, computer, harness, pedal, TAC module) through LKQ w/88,xxx miles, Fbody LS1 oilpan+ windage tray+pickup+new gaskets, new GM clamshell LS mounts, Spohn polyurethane bushings, Spohn LSX adapter plates, 4th Gen F-body fuel tank, 4th gen F-body coolant tank.
I am planning on using and abusing the stock 700r4 until she gives out and will eventually build up a 4l60 or 80e for it.
I work at my family business which is an automotive repair facility specializing in exhaust. I will be getting the Hawksthirdgen long tube headers and using out mandrel bender to build custom exhaust. Hopefully true duals but I am probably just dreaming
I will start to post some pictures tomorrow of the car and what not but for now I am excited as ever to get a start on my ride!!!!!! Engine should be here Friday
Are you going to keep it dbw or go cable throttle.I personally prefer cable.
Good luck on the build.
-LS1 or LS6 Intake
-LS1 or LS6 Fuel Rails
-LS1 or LS6 Injectors
-Fuel Pump (Not sure what I am going to need here w/ the 4th gen tank that I have)
-LSX Swap Headers from Hawks
-4th gen LS1 accessories (crank pulley, water pump, tensioner, power steering pump + bracket, alternator + bracket, idler pulley, serpentine belt)
-Cam (undecided on what to get)
@RedBull87- I am planning on sticking with the DBW but I am not against looking into DBC if it is easier/cheaper. Also I will be going through the motor doing routine maintenance as well as the cam before I put it in.
Engine is going to be here on Monday now as it is being pulled today and shipped out of Texas.
I am in the process of trying to get some pictures up but I am having trouble figuring out how to get them on here as my file sizes are way too large. I will definitely have some pictures by Monday if not sooner.
start a photobucket account(it's free) and upload your pictures there...then you can put them in your posts easily.
the build up thread of my 91 z28 is in my signature.
there are a lot of great cams out there...decide how you want to use the car and go from there.
After getting situated in the garage I got the 98-02 clamshells pulled apart and put the new spohn polyurethane bushings in. Then got the old clamshells off of the k-member.
Also I've got a plastic dummy LS block so I can get things mocked up.
velox65 I'm picking up a 89 ws6 formula 350 this weekend, I was actually about to start a thread asking for ideas, are you using the stock k-member or going tubular?
I want to do the T56 but I am still up in the air as to what I am going to do. Probably run the stock 700r4 until she blows.
[/IMG]
