Need help: Ls1 in a 94 lt1 trans am
Old Jun 6, 2012 | 03:02 AM
97Lt1TA's Avatar
Default Need help: Ls1 in a 94 lt1 trans am
I have a 94 lt1 trans am i picked up to fix up and i have a ls1 motor out of my old z28 just laying which i started thinking about just putting the ls1 in that trans am to enjoy this summer.
my main issue is the wiring. If i decide to go with the project, i want to know how hard is it to make a ls1 work in a obd1 car due to the wiring differences.
another thing if im not mistaking i heard i should put in a 99+ fuel tank but still use the pre 99 fuel pump assembly in a swap like this.
Pretty much my main concern is if its worth doing this swap or should i just stick with the lt1 in that car and find a 95+ f body to put the ls1 in
Old Jun 6, 2012 | 10:35 AM
the_merv's Avatar
Veteran: Air Force
Pretty simple to do. 94 isn't really that much different..don't touch anything on the fuel system wiring on the car.
https://ls1tech.com/forums/conversio...on-sticky.html
Old Jun 7, 2012 | 05:36 PM
97Lt1TA's Avatar
thanks for the link im going to be doing my swap using the info you put down.
also will the lt1 fuel line hook up without a problem to the ls1 fuel rails??
btw i remember that red z28 you had , i was going to buy the lt1 motor with lt4 cam form you a while back for my old formula
Old Jun 7, 2012 | 10:07 PM
the_merv's Avatar
Veteran: Air Force
That was a long time ago.. Lol..
Look in that thread, the fuel system has to be modified with the corvette regulator.
