Oil in intake, SMOKIN!!
It concerned me at first, but after about a 45mi trip, I didn't see anymore. Later that day, I installed a gasket between the intake and throttle body and noticed the throttle body flap was wet with oil.
My guess(after a day or so of thinkin) is that I've put too much oil in the engine. I've changed the oil pan from the truck to car version, but didn't change the dipstick. With that in mind, does that mean the truck dipstick showing full, actually is showing more than needed?
Whadya think?
Is there oil inside the intake (on the bottom) ?
BC
Just to give an idea of what I have, all I'm using right now is heater hose for the pcv system.
Is that adequate or do I need to go a different route when I install the catch can? Also, which catch can do I use? Tryin to cut down some trial and error time.
Most if not all PCV system need to ports, one for fresh air (should be metered, downstream of the MAF) and one that provide vacumn and sucks the fumes into the intake track.
BC
BC
Go into the GenIII external engine section & search PCV. There you will find most of the answers. No, you do not need different valve covers.
In the end, many of us have found (when using a PCV connected to intake vacuum) that a catch can on the dirty side & a catch can or in-line fuel filter on the clean side works best in keeping oil out of the intake.
dirty side = from rear driver valve cover to intake vacuum
clean side = from just ahead of TB (filtered & metered air) to passenger valve cover
I have it setup the same way on my 408..with a Norris Catch Can tho just to see if it pushes oil thru the vent lines. I check it every oil change, which is prob every 2500 miles on that..it maybe has a slight film of oil in the bottom.
IMO pcv is over-rated environmental junk..the purpose is to pull the crankcase pressures, but if it's vented it doesn't build up pressure. That and an engine stops pulling vacumn around 3500rpm or so(I've read that in a few places..didn't make sense to me either..), so at WOT pcv is not functioning. Lots of the big racecars have either vents or vacumn pumps..fwiw.
http://shop.advanceautoparts.com/wcs...6_pri_detl.jpg
Yes, if your choice is to eliminate the PCV & vent the valve covers to atmosphere, those will work. Be advised that oil will push through the filters & run down the outside of the valve covers & the engine from time to time. That's why Merv noted that he ran 3/8" hoses down the side of the block & pointing to the ground.
