Rebuilding Dad's Panoz; LS1 swap
Old 03-11-2013, 08:34 PM
  #121
Cobra4B's Avatar
Fresh bedliner, low oil pressure light, and moved the wideband.
Old 03-14-2013, 08:50 AM
  #122
Cobra4B's Avatar
Fuel cell straps needed paint... might as well go with red.
Old 03-21-2013, 09:16 AM
  #123
Cobra4B's Avatar
Wiring progress. Determining the optimal layout was the hardest part.
Old 03-22-2013, 08:51 AM
  #124
Cobra4B's Avatar
Caliper mount flanges squared and gussets added. Outsourced this bit to a local shop Mike Balf Race Cars.
New brake and clutch masters and new pedal mount. Old mount was worn out. The bores where the pedal pivots go were hogged out into ovals allowing the pedals to move in the mount.
Old 03-23-2013, 09:10 PM
  #125
Cobra4B's Avatar
Today I setup the pedals/hydraulics (balance bar, lines, etc.) and made my new switch panel. Very pleased with how the switch box/panel came out... exactly what I dreamed up in my head. Found the box from Jegs, made by K&R racing... only $30. Bought the switches separately and made the panel with ABS plastic I already had.
Switches from left to right are:
Start
Fuel Pump
Igntion(MSD)/Gauges
Fan (50 amp switch)
Cool Shirt
Aux (will power a power port on the dash for anything that uses a cigarette lighter adapter i.e. Traqmate)
Old 03-25-2013, 08:24 AM
  #126
Cobra4B's Avatar
Wiring... this stuff is tedious. I couldn't imagine doing it on a "normal" car with less access.
Old 03-25-2013, 12:29 PM
  #127
tired2valve's Avatar
Looking good
Old 03-25-2013, 06:31 PM
  #128
zuffen's Avatar
You could have made it easier on yourself by using color coded wires rather than all one color.
Think how it will be in 3 years time when a wiring problem arises you'll have to trace each wire individually to identify what it does.
Old 03-25-2013, 07:33 PM
  #129
Cobra4B's Avatar
West Marine fancy grade 12 gauge 100' spool (10 gauge for the fan circuit). Didn't want to mess with buying all kinds of different colors. Red for power and black for grounds... KISS.
Plus, I put write-on/print-on heat shrink wire labels on everything.
You can see them on the leads from the switch box here...
  • Label coming off each switch lead for fuse side and load side.
  • Label coming off each fuse panel wire so I know which to hook up to which.
  • Fuse panel cover will have labels for each circuit.
  • Label at the end of each load wire.
I dun planned ahead
Old 03-25-2013, 08:36 PM
  #130
Keith's Avatar
As I was scrolling down looking at the fuse block, then the wire terminals, all I could think was West Marine.
Good on ya, thet's some high quality stuff there.
I used to work there and bought all the stuff to wire my car from there. The employee discount really helped.
Old 03-25-2013, 08:37 PM
  #131
Keith's Avatar
Old 03-25-2013, 08:53 PM
  #132
MMWS6's Avatar
You sir... are full of WIN! Wow, what a build
Old 03-26-2013, 06:22 AM
  #133
WKMCD's Avatar
Great thread Brian. Let me know when you come up to Summit. I probably have 1000 laps on that track...on two wheels.
Old 03-26-2013, 09:46 AM
  #134
Cobra4B's Avatar
Going to try and make it for the NASA event next month to shake-down the car. I was fortunate enough to set the TTA record there in late 2011 with a 1:17.8. The previous record was a 1:20.3.... was my first time at the track too. Fun little track... front straight speeds are pretty nuts.
Old 03-27-2013, 09:42 AM
  #135
ss454327's Avatar
I'd get that FRAM out of there ASAP...
Old 03-27-2013, 10:03 AM
  #136
Cobra4B's Avatar
Break-in filter only... not going to use a $15 K&N for first start-up and break-in dyno time. Have two cheap Frams and then will switch to the normal K&N racing filter.
Old 03-29-2013, 08:37 AM
  #137
Cobra4B's Avatar
Before
After... done in "wheel silver" with clear from Precision Powdercoating.
Old 03-29-2013, 11:27 AM
  #138
SatisTraction's Avatar
nice clean build!!!
since you hate ford so bad what kind of deal can i get on those ford heads?
Old 03-29-2013, 12:17 PM
  #139
Cobra4B's Avatar
Originally Posted by SatisTraction
nice clean build!!!
They're AFR165s with nearly new springs and comp pro magnum roller rockers etc. If you send me an email I can put you in touch with my father who's selling all that stuff. Not sure if he's listed the heads yet.
Old 03-29-2013, 03:54 PM
  #140
PontiacPOWA's Avatar
Good call on the powder coat color, that white chassis looks great. Cool build
Quick Reply: Rebuilding Dad's Panoz; LS1 swap
