LS1 1992 TYPHOON project
Old Jul 15, 2012 | 09:56 PM
AlhozamiAutoali's Avatar
Post
Wow thats a shame someone let one of those get in that condition.
it used to be perfect condition but after staying in the sun for 6 months its started to get messed up
Old Jul 15, 2012 | 10:05 PM
Question
Originally Posted by Stormed_Norm
Your biggest problem is the oil pan. There are a couple pans out there that have been used. RPM in Cali was selling them, not sure if they are anymore. Otherwise if your helper can weld aluminum that is your next option. I used a hummer pan on my ls swap in the ty. Had to cut it and reweld the bottom and the sump area to clerear the front diff. Your next biggest problem is no money. Getting a exhaust and wiring and a few other items are not free. You might want to check out syty.net or v-8s10.com and see what's going on there.
thanks for the info my bro already has the hummer oil pan and unmodified it didnt fit but as you said there is a way to make it fit.... anyway i heard that there are some oil pans that external tanks .. does anyone know of something like that???
Old Jul 15, 2012 | 10:10 PM
Thumbs up
Originally Posted by LSCha0s
It took me over a year and 6k$ and I have been working on cars for 20 years. I think you bit off more than you can chew. On the other hand my first major undertaking was at 18 I swapped everything including wirring from a 76 Camaro to a 73. There was no internet back then to help me.
GL
i got the car already made to mount the engine thats why it seems like it wouldnt take much time .. and there is also alot of very experienced car guys guiding me through ..
thanks alot for the support i really need it from experienced guys like you...
Old Jul 15, 2012 | 10:22 PM
Cool
Originally Posted by 1dirtyZ
guys what you don't know is his brother and cousin are car nuts through and through , plus he will have my help too
if anyone can do this project, this kid would be the guy to do it .
i need that ls1 to 700 transmission adaptor though... got one of those??
Old Jul 15, 2012 | 10:26 PM
Originally Posted by xmbreezy
I finished my first S10 ls1 swap within a couple of months. The biggest issue was money, you never really understand how much money is going to be thrown into a swap project until you start doing it. Don't forget you need to do wiring, exhaust, fuel system, cooling system. If you want power steering and a/c (if applicable) it's also going to cost you.
Your best bet is to take of the radiator support to make it easier on yourself when you put the motor in. If you get the fenders off all it takes is another two bolts to take it off.
Good luck and get a job!!! hahah. I have thrown probably 15 grand into my swap project because I used good parts and took short cuts where safety wasn't an issue!
well because of the low budget the parts are most probably gonna come from either a scrapyard or someones warehouse .. so everything will be modded to fit .. and when the time and cash is in place thats when the scrap parts will be added with good ones ..
Old Jul 16, 2012 | 02:52 AM
Originally Posted by Eaglefreek
Correct, you can not drive the vehicle with the front driveshaft disconnected without damaging the viscous coupler in the transfer case in a very short time.
So what can I do to prevent this ????
Old Jul 16, 2012 | 08:27 AM
Post Update
my internet was not able to upload videos so i delayed this update ..
anyway day 1 of working i was able to finish steps 1 and 2..
the two front wheels was stolen so the previous owner put in el camino rims for transport and the rears are still the original typhoons anyway it looked undecent so i bought these decent pair of wheels (100$ with tires) and i realized that its made by gm???
so i looked for it and found alot of camaro's with it.. still not sure though its says abs in the middle and has a GM engraving in the back of the rim ...anyways i installed them and fit perfect my bolt pattern is the same as the camaro's
... after that i wanted to remove whats left of the front drivesystem which is the driveshafts and it only took me around 7 minuits to take the whole system heres a photo of the left wheel hub
my steps
1.install a wheel that the socket could go through in my case i used the camino rim just to hold the wheel hub in place while unscrewing the nut
2.remove the pin on the driveshaft bolt
3.remove the nut locker it gets loose after you removed the pin
4.remove the nut
5.keep hitting the bolt till its completely loose inside
6.if there is resistance maby its because the driveshaft is hitting the shock mount as shown here
after that pull from this end till its completely out
and your done
so that was all that i did in day one anyways i also have a video for the whole process of me removing it here : http://youtu.be/O0wqXE7nnjM forgive my poor literature
Old Jul 16, 2012 | 08:37 AM
Default Update
so for day two i had limited time so i thought what was an easy and fast job well the front clip was only held by two bolts on the top for transport and i thought it wasnt that heavy so thats exactly what i invested my time with and i was planning to bring in the ls1 after two days so im installing it with the front clip off... the front clip's condition is not really ''solid'' alot of stuff were cut out specially when they needed to extend space for the radiator when the previous owner tried to install an lt1 so i bought a new front clip which was in great condition but was from an s10 blazer not a typhoon or a syclone so i had to move the front fenders to that one if i was going to intstall it i will have to see if i do need the space cut out for the radiator in the original front clip if not im planning to install the other one.
anyways heres a video of the whole removal as i said it was only held by two bolts so there was no instuctions needed..
http://youtu.be/LO_bBmVraBk
Old Jul 16, 2012 | 11:27 AM
Eaglefreek's Avatar
Your options are to not drive it, hook up the front driveshaft or install a 2wd transmission and delete the transfer case.
Old Jul 16, 2012 | 02:30 PM
eviltwin_1987's Avatar
What's the last 4 didgets of the vin?
Old Jul 17, 2012 | 05:34 AM
Post LS1 pickup
Went to the warehouse last night (me and my brother) to pickup the ls1 and the TH700R4 trans here's the warehouse
oh yah and the two trucks are a 1993 chevy truck ss454 swapped 8.1 and a 1972 chevy truck c20 stock which has alot of stuff on the bed
we took the ls1 from a 2001 caprice v8 (in saudi arabia) and it has a 4l60e transmission attached to it so we had to remove that first to install the 700 trans
so i took of all the transmission bolts and we started seperating the transmission from the engine
After that we brought out the th700r trans which already had the Borg Warner 4472 transfer case installed to it that we took from an astro van awd
after that we strapped it together with the ls1 for transport
then now we needed the hummer h3 oil pan .. it was already a previous project to intstall a gm 4.8 into the typhoon before so i took it off the old engine
and after that we loaded everything on the truck and went home
Old Jul 17, 2012 | 05:35 AM
  #32
i forgot.. but when i get home i will check it out
Old Jul 17, 2012 | 05:37 AM
  #33
Question Question
oh guys i really need to know if the 4l60e torque converter will fit in the th700r4???
Old Jul 17, 2012 | 11:25 AM
  #34
sierrac3_s2000's Avatar
Why aren't you using the 4L60E transmission? You said you aren't hooking up the front differential which as you already know will kill your transfer case so I don't understand why you wouldn't use the trans that was originally with your engine. Its already programmed for it. You are making your swap much more difficult by not using it. If later on you wanted to try to go AWD you could just as easily get a 4x4 4L60E and AWD transfer case and it would be a direct swap.
Old Jul 18, 2012 | 04:52 AM
  #35
1dirtyZ's Avatar
i agree with sierra , why not go with the 4L60 trans ( unless your cousing has a "project" lined up for it )
drop that engine and the 4L60 trans , hook up the driveshaft and pcm and you are almost done
and by the way , those wheels are off a firebird if i'm not mistaken.
and i got to give you credit for documenting all your work you will find it comes in handy when you need to check if you did something or not later down the road.
Old Jul 18, 2012 | 05:46 AM
  #36
Post
I'm thinking now of going with your idea. But before that I plan if putting the 700r4 as a mockup with transfer case and measure everything up and finish the exhaust then after that I will put back the 4l60E and install it with the ls1 and use is at as a 2wd till I get all my parts gathered for the awd system
Old Jul 18, 2012 | 05:51 AM
  #37
Post
My car is number 0514
Old Jul 18, 2012 | 10:13 AM
  #38
1dirtyZ's Avatar
good point .
Old Jul 18, 2012 | 11:32 AM
  #39
If I were you I would forget about the 700R4 and just get a 4L60E with a AWD transfer case. Something out of an Escalade or a Denali truck would work. I would also look into the Trailblazer SS front differential and oil pan. I bet you could make them work. Might take a little cutting and welding but what swap doesn't?
Old Jul 18, 2012 | 02:24 PM
  #40
jmd's Avatar
jmd
Post
It's a 20 year old vehicle with zero rust. Oh No! For me, the most important thing is that it's out of the sun.
Now we know it will get done.
GM 12563532
Only early 4L60-E converters work in the 700-R4 because the TCC system is non-pulse width modulated.
I find myself agreeing with this.
Good luck with your swap and keep documenting the integration of the AWD as you work!
