LS1 1992 TYPHOON project
Old Aug 15, 2012 | 07:19 PM
  #61
Stormed_Norm's Avatar
Default Adapter
Originally Posted by 1dirtyZ
who makes the adapter ?
Here's where most of the guys on the syty forumn got theirs. :
http://www.sytyperformance.com/index...mart&Itemid=26
Old Aug 26, 2012 | 04:35 AM
  #62
AlhozamiAutoali's Avatar
Post
google is your friend
i remeber seeing one over here that had a local shop build a set of headers for him.
i'll check on that for you .
1dirtyZ just wanted to ask you what is the kind of brake booster you used here:
Old Aug 26, 2012 | 07:11 AM
  #63
1dirtyZ's Avatar
its a mini booster for the camaro (1970). if i recal correctly i got it from SSBC i think.
Old Aug 26, 2012 | 07:13 AM
  #64
Post
is the efficency any good??
and how much did you get if for??
Old Aug 26, 2012 | 07:40 AM
  #65
Search on e-bay. Type in street rod brake booster. There several styles to choose from.
Old Aug 26, 2012 | 11:43 AM
  #66
1dirtyZ's Avatar
can't tell you on both questions , the first is because i still don't have the car runing , and the second is because i don't remeber
Old Aug 26, 2012 | 12:56 PM
  #67
Post
ooookk... well i will just have to then
Old Aug 26, 2012 | 02:00 PM
  #68
Post
my brother ordered the headers from s10v8.com already and it seems like the project is going to come alive again... my cousin finally found a 2 door blazer that im gonna take alot of parts from, some parts to list are rear driveline, fuel lines and brake lines and probably alot of other crap that i will discover in the future,
i will try to keep it as updated as i can..
Old Aug 26, 2012 | 05:28 PM
  #69
1dirtyZ's Avatar
looks like youre on the right track, how about some more pics
Old Aug 27, 2012 | 04:53 AM
  #70
Post
for sure i will upload some when i get home
Old Aug 27, 2012 | 05:03 AM
  #71
Post
speaking of pics .. here is a photo of the headers i ordered
i think the brand is patriot "not 100% sure though"
info:
For LS1 in S-10 and Blazer.
Very tight fit and good plug access.
Includes all hardware necessary for installation.
Fits 4.8, 5.3, 6.0 Vortec engines
and LS1, LS6, LS2, LS7
1-5/8" Primary Tubes
3/8" Flanges
18 Gauge Tubing
2 1/2" Collector (collector already fitted for 02 sensor)
Old Sep 9, 2012 | 07:17 AM
  #72
Post
BAD NEWS!!
the company "s10v8" was suppost to send the headers to an address of a forwarding company "aramex" which will send it to saudi arabia but unfortunately they said that the dont want to do it heres the email
Date: Aug 28, 2012 5:05 PM
Subject: Re: S10V8.com Parts Store: Your order #9375 has been declined
To: "Mansor Alhozami" <XXXXX@gmail.com>
We are unable to ship this order. We can not and will not ship orders
to shipping companies. This type of transaction is not covered by our
credit card processing company and therefore leaves us completely
responsible for anything that happens, fraudulent order, loss of item
in transit, etc, we are not going to take the risk. Sorry for the
inconvenience.
On Tue, Aug 28, 2012 at 6:09 AM, Mansor Alhozami <XXX@gmail.com> wrote:
> I live in Saudi Arabia , I have Forwarding address in NY in my name , The
> Visa also in my name (attached find copy) , also the amount already booked
> from my account !
> I hope all above enough to release the order , other way show me any other
> way to order this parts because i need it urgently to my project .
hmmm...
Old Sep 9, 2012 | 07:28 AM
  #73
Post
so after this mishap was cleared out i found another website called currentperformance.com who speciallizes in wiring but they have lsx conversion parts.. there i found they had sanderson shorty 1 5/8 headers and ordered them right away ...
till now there is no confirmation on when they would arrive but it should be here in about two weeks..
before then i will restore other parts of the car as well as checking the fuel tank to see if the fuel pump is a high pressure pump enough to support the ls1
Old Sep 9, 2012 | 08:11 AM
  #74
sparkwirez06's Avatar
those sanderson shorties will not work,awd they are for a 2 wheel drive.
Old Sep 9, 2012 | 08:15 AM
  #75
yes i know... its close to impossible to find awd headers for lsx swaps due to the variation of setups which is why people just make it a turbo setup instead
when you did your project did you already planned the turbo setup??
Old Sep 9, 2012 | 05:23 PM
  #76
1dirtyZ's Avatar
i have a set of block huggers i'll get you and you can see if they fit or not .
worse case scenario you can always have them custom made locally .
Old Sep 9, 2012 | 11:23 PM
  #77
BudRacing's Avatar
Glad you found Current Performance, they've been a real asset to the s10 swap community.
Old Sep 20, 2012 | 04:07 AM
  #78
Post
Its been awhile since i updated so i just wanted to tell you guys about the progress ...
all this time i was pretty much fixing and restoring the interior ..
i removed the rear air suspension compressor and air shocks are replaced it with monroe sensatrac's...
i took out the fuel tank and took out the fuel pump...im still looking for a high pressure fuel pump that would fit..
i ordered the flywheel spacer already and its on its way the headers still didnt arrive till now..
my brother told be something about the ls1 ecm ... he said that i couldnt run the car unless the ecm gets unlocked....i dont really understand what he meant.. and he doesnt know the details..do you guys know what this is??
Old Sep 20, 2012 | 11:24 PM
  #79
For the ecm you have to get the anti theft program taken out of it. As for the fuel pump drop in a walbro they work fine for what your doing.
Old Sep 21, 2012 | 03:13 PM
  #80
1dirtyZ's Avatar
don't worry about the pcm , when the time comes to start it , just tell me and i'll take care of it
did you look into the aeromotive 340 pump?
