Registration Problems in Missouri
I took the car to a shop in the St. Louis area to be inspected last week and figured everything would be fine. Wrong. The mechanic at the shop realized it had and engine swap, it's easy to hear that, and called the Highway Patrol to find out if it was legal to pass the car. The Hi Po says no, because the car doesn't have an engine that was an original option for the car. I called them myself later and got the same thing and I think this interpretation comes from this section of the "Rules of Department of Public Safety" for Missouri
"Effective July 1, 1992, all light-duty
vehicles which are passenger vehicles with a
Gross Vehicle Weight Rating (GVWR) below
six thousand pounds (6,000 lbs.) and commercial
vehicles with a GVWR below eight
thousand five hundred pounds (8,500 lbs.),
which receive a replacement engine, in
regard to all emissions related parts, engine
design parameters and engine calibrations,
must comply with the certified configuration
of the same or newer model year as the vehicle
chassis."
I guess because the engine was never "certified" for my chasis by the EPA they throw the flag. The shitty thing is all cars in Missouri 1995 and earlier are emissions exempt!
Has anyone out there in the St. Louis area into this with there swap? With so many cars out there with LSx swaps I figured some has run into this. It almost seems easier to get plates in California! Any help or info would be much appreciated.
Ask if they have re-certification rules/policy to pass the car as the new Donor engine and not the Body.
Many other states will base there DMV rules and laws based on the California C.A.R.B. laws. http://www.bar.ca.gov/80_BARResource...uidelines.html
Good Luck
BC
Somewhere there has to be a shop that has a mechanic that will think your car is just cool. Whatever you do, I highly recommend you DO NOT go anywhere near the Highway Patrol. They can make you jump through all kinds of hoops you don't want to get involved with. The Best V8 Stories One Small Block at Time
It's just saying that a 1995 car must have a 1995 or newer engine swapped with "certified configuration" so you basically need all the emissions equipment of the LT1.
Now, your cop and mechanic passing 6th grade is potentially more miraculous than a car in Missouri actually having all the emissions equipment.
The point is, they mis-understood it due to lack of job-training so follow up with the state MVD.
Missouri law cannot make illegal what Federal law specifically legislates as legal.
You're clear on the GVW thing because both donor and recipient are in the same class.
Thanks for the comments and suggestions.
Here is my ride:
Here is what the shop owner drives:
At the drag strip in Adrmore, OK; 13.3 @105 on used street tires!
Ford 8.8 Swap:
Early Engine Shot (now has cruise and A/C):
What I started with inside ( I had already intalled the heater box in this picture, that was also missing when I bought it):
chassis."
"...in regard to all emissions related parts, engine
chassis."
so the engine design parameters are nowhere near the same as a 77 or newer Volvo 244. "Model year of the vehicle chassis" meaning 1977 Volvo 244.
If the car is emissions exempt, it's a moot point and you just happened to talk to the 2 dumbest people in the state. If it's not exempt, you're gonna hafta get sneaky about it. I feel for you. Been there. I had 2 V8 Chevy Vegas, when Calif first started smog inspections. Yeah... I'm THAT old!
