Lets say I wanted AC
but its a mid engined car, and it never had provision for AC.
what is the simplest cheapest lightest and smallest way to get AC in a car that never had it, and has no heat?
I don't really want to add the weight, the cost or the complexity. but damn, these recent hundred degree days have been killing me.
and is there by chance a removable AC option?
I bet you could make a similar set up for a car, but it wouldnt be good for much but real short trips.
I will check out some of the other companies. my problem is the engine is in back and the radiator is in front, so Id have to run some very long AC lines.
http://www.ebay.com/itm/1950-60s-vin...sories&vxp=mtr
Either of those mini evaperators will work, just need a condenser and a dryer, the fittings are relatively cheap, the hose about 3.50 a foot, how much your local shop charges is the question, I install and this is what it costs me. For the inside lines that you can asemble, use the EZ clip that Vintage air has, they are a lot more flexible than the beadlock type line, as far as that goes, you can use them anywhere, that leaves out the shop that crimps your lines, however the EZ clip fittings are a bit more... Good Luck.....
I use this cause it pisses Obozo off The AC compressor has to go on first, and once the body is mounted removing the alternator will require either pulling the body or pulling the motor and transmission (ya, its that harsh, working on options)
The compressor bolts onto the side, and I think the lines come out the side as well, leaving it open to be easily worked on later. if in the end I decide to scrub the AC I can just cut the AC belt and pull the compressor off.
I want to make the rear panel of the front of the body removable to avoid such issues, but that removes a LOT of the rigidity of the body, I hope to put a roll bar back there and securely mount the roll bar to the body and have the roll bar bolt to the frame. then the bar will make up for the suport and I can still unbolt the bar to remove the body.....
LOL..
But yeah.. check out those Classic or Vintage Universal kits.. they have a few unit that are pretty small.. and if it is a mid-engine Car.. I would assume that the interior is pretty small and would not need a very large capacity one at all.
BC
http://www.nostalgicairparts.com/
