Fox body Header problem...Help
Old Jul 19, 2012 | 08:00 AM
streetknight2's Avatar
Default Fox body Header problem...Help
Hey guys. I'm using the AJE K member but used the stock mustang trans cross member. The problem I'm having is on the driver side the collector is obstructed from hooking up an X pipe by where the cross member connects to the body. Has anyone else had this problem. Using Dynatech headers.
The exhaust shop told me the only two options they could think of is to build a different trans cross member and cut the mount off the body or cut the collectors on the headers back some.
What do you guys think? Here's a pic, not the best in the world though.
Old Jul 19, 2012 | 10:11 AM
1bad03snake's Avatar
The exhaust shop cut about an inch off each of my collectors and put a slight bend on the driver side.
Old Jul 19, 2012 | 10:21 AM
Thanks, I may be able to cut them off, but bending not so sure, My shifter linkage is only about a 1/4" from the collector as it is.
Old Jul 19, 2012 | 10:48 AM
windmill's Avatar
u sure u not got the crossmember backwards the big hump goes to pass side
Old Jul 19, 2012 | 10:55 AM
Yep monk, that's the way I got it
Old Jul 19, 2012 | 12:18 PM
windmill's Avatar
i went and looked at mine,,, looks like ur header is bent outwards,,,,
Old Jul 20, 2012 | 12:22 AM
Mine fit the same way. You could trim the x member a little and that should help
Old Jul 20, 2012 | 06:13 AM
Gray86hatch's Avatar
Just cut the collector back. This is very common
Tim
Old Jul 20, 2012 | 06:48 AM
Thanks guys
Old Jul 20, 2012 | 07:49 AM
Ok guys, now I got the plugs and wires on and the #3 plug wire is hitting the primary tube. I'm using the MSD 32829 Multi Angle plug wires.
What do you think my options are? I've seen some heat socks at Advanced Auto Parts but not sure that will be ok. Or should I try a different kind of wire on that cylinder. Thanks
Old Jul 20, 2012 | 01:29 PM
Just bend the boot a little.
Tim
Old Jul 20, 2012 | 02:34 PM
LS1PUNK's Avatar
I did a coil relocation to avoid this.
Just a idea.
Old Jul 23, 2012 | 11:12 AM
Ok, got the car running. Now need to figure this exhaust out. Wanna have the rest of my stuff here before I go to muffler shop to see what they can do about this collector.
My plan is 3" X pipe into bullets with turn downs. What do you guys think? Was gonna get the universal kit from summit unless someone has a better idea lol
Old Jul 23, 2012 | 12:35 PM
I have a summit x on my car and the h I built over the winter is .10 faster.
Tim
Old Jul 23, 2012 | 12:48 PM
So you think the summit one has a poor merge?
Old Jul 23, 2012 | 12:54 PM
It is not the best. The more the air has to turn the less power it will make it
I was surprised with my car
Old Jul 24, 2012 | 09:18 AM
Here's a better pic of what I'm running into on the driver header. Since I've heard this is a "common" problem. Does this look about normal? I used a T5 mount cause a TH350 mount made the engine tilt back 6 degrees.
What do you think?
Old Jul 24, 2012 | 10:07 AM
Just trim the collector and put a 45 on it. To get the exh up high in the car it needs to be up in the trans tunnel anyway
I will post a pic of mine tonight
Tim
Old Jul 24, 2012 | 10:39 AM
Thanks Tim. I'd appreciate the pic. Ready to get this thing knocked out and to the track. Been on it since November.
Old Jul 24, 2012 | 07:43 PM
