Opinions Wanted - what year 4L60e / 4L65e
2004 5.3L in a 1970 Chevelle.
Cruiser, not a racer. Fuel mileage is the reason.
What year overdrive transmission should I be looking for?
If you are just leaving it stock it probably won't matter, but I believe 2002+ had some revisions that made them a touch stronger from the factory. Don't quote me on that year though. A 65 is going to have a 5 pinion planetary from the factory which also is a bit stronger.
The 4l60e family 4l60/65/70 all have the same gear ratios and over drive. Only advantage is minor strength increases among them.
Any Gen III/IV 4l60/65/70 from 98-2007 will work. Make sure it was used with a Gen III/IV V8 as it could have the wrong converter to work with a 5.3L
somewhere I read a 700R4 Transmission Extension Tail Housing will fit on a 4L60 transmission and allow for a cable driven speedometer.
Is that correct?
Is that correct?
PCM control did not change from 95-08. 94's and older did not have a PWM function which doesnt not play well with LSx PCMs for swaps
Is that correct?
Is that correct?
