LS1 install update pics.
Old Apr 4, 2004 | 09:03 PM
Budman78's Avatar
Launchin It!
Default LS1 install update pics.
Well after a month and a half of trying to get the clutch to work, it's finally functioning. I guess Centerforces idea of malfunctioned clutch is different than mine. And after buying 3 slave cylinders, 2 master cylinders, and one replacement pressure plate the hobby is getting a little expensive.
Fuel line is install, wiring harness is on it's way, and then off to the muffler shop. After that I'm going to have it programmed and dyno tuned.
http://temp.corvetteforum.net/c3/bud...s1_april_4.jpg
http://temp.corvetteforum.net/c3/bud...ls1_intake.jpg
http://temp.corvetteforum.net/c3/bud...1_top_view.jpg
Old Apr 5, 2004 | 07:23 AM
67ls1CamaroProject's Avatar
Looks good!
But, you know you can flip the fuel rail around so that it is on the same side as your fuel line supply. It would look better. IMO.
Old Apr 5, 2004 | 10:41 AM
Mark IXZD 150's Avatar
Originally Posted by 67ls1CamaroProject
Looks good!
He's right. Flip that fuel rail around and swap covers which will make the fuel line a lot shorter and cleaner looking. Nice looking install!
Old Apr 5, 2004 | 11:00 AM
Scooter70's Avatar
Really? Then you have to swap the valve covers so that the filler is on the drivers side too, right? I never thought of that.
Old Apr 5, 2004 | 11:30 AM
Budman78's Avatar
Launchin It!
The fuel line is just laying there. I will plumb it behind the block on tabs. Once the harness is in, you want even see it.
Thanks for the tips.
Old Apr 5, 2004 | 12:34 PM
Yea, they should be able to rotate as well. You'll just have to reroute your EGR tubing, but that's easy enough.
Old Apr 5, 2004 | 01:13 PM
70 LS1's Avatar
Conversion master
Looks good Buddy. I was going to go with a braided line just like you did, but I cheaped out and went with an aluminum line with AN fittings instead.
Old Apr 10, 2004 | 07:24 AM
Budman78's Avatar
Launchin It!
Thanks, Guys.
Jeff - I went with the braid just to add a little chrome. I'll probably add some more "shiney" as I go.
