04 GTO Wires
Old Aug 12, 2012 | 09:10 PM
xyster's Avatar
Default 04 GTO Wires
I have searched and searched with no luck. Is there a drawing of the wiring for a 04 GTO like the ones i have seen for the 98-02 F-Body's that show which wires that ned to be used to make the engine work? You know like the wiring diagrams that show the connector numbers and pin number/letters and where it is to be connected. Anybody please
Old Aug 12, 2012 | 09:13 PM
aknovaman's Avatar
http://chevythunder.com/2004_gto_pcm_pinouts.htm
2004 gto harness is almost identical to the 2002 camaro but with slightly different colors. Pins are the same.
Fast enough response......
Old Aug 12, 2012 | 09:23 PM
Sburch5887's Avatar
Default 03-06 pinouts
http://lt1swap.com/2004vortec_pcm.htm
This one is a little easier to follow, its what I use to build all of mine, I have built several of these harnesses & now I know them inside & out thanks to this link. Good luck, if you have any questions, feel free to send me a message.
Old Aug 12, 2012 | 09:40 PM
rotor vs. piston's Avatar
n/m, the first post was enough. Gotta love these forums.
Old Aug 12, 2012 | 09:52 PM
62n62's Avatar
Default diagrams like this
Old Aug 13, 2012 | 06:46 AM
psiconversion's Avatar
LS1Tech Sponsor
Just an FYI, the GTO harness uses a Green/Blue PCM which has a few extra grounds and pulse width modulated O2 heaters. Still similar to the F-body as AKNOVAMAN stated.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Aug 13, 2012 | 07:18 AM
attilahooper's Avatar
I have the scans of the diagrams that 62n62 posted. PM me if you need them.
Old Aug 13, 2012 | 01:16 PM
69 Ghost's Avatar
You can still use a 02 harness with a 04 GTO PCM but you will have to turn off the heater diagnostics on the PCM. Everything else including A/C, fans, etc works the same way and should be wired as such if needed.
Old Aug 13, 2012 | 03:22 PM
xyster's Avatar
I just want to use what i already have which is a 04 GTO LS1 and harness. I have the pin outs of the ECM so my next question is what do I do with them? Do I cut the wires on the pins i need to use and connect power and grounds to those going into the ECM if so what about the other end of the wire I cut where is it going? I have the C206 connector but I dont see a C101 that a few people have talked about in other posts.
