My 1965 Buick Skylark L92/6L80 Swap
Old 05-14-2014, 01:21 PM
  #421
1989GTA's Avatar
Getting the car ready to take to the track. The Hoosier drag radials came in today. Actually this is all I really need at the moment to make some shake down passes as I already have the skinnies for the front. I have had good luck with the Hoosier tires on my 1989 Trans Am and decided to stick with them for the Skylark. One tire weighs 21.6 pounds. Here are a couple of pictures.
By the way the 160 degree thermostat is working a lot better. I think I had air in the system from changing the thermostat. Even in 90 degree weather like we are having now. So it will be a keeper.
Old 05-14-2014, 01:33 PM
  #422
Old School Heavy
speedtigger's Avatar
It's gettin' real up in here!
Old 05-14-2014, 02:25 PM
  #423
1989GTA's Avatar
Yep, getting closer.
As to weights, here are some numbers. My front tire weighs 29 pounds. Front rims weigh 22 pounds. Wheel and tire weigh 51 pounds each. The skinny with wheel and tire weighs 27 pounds. So that is a savings of 24 pounds per tire or 48 pounds total up front and rotational weight at that.
On the rear the wheels are probably about the same weight as the front. The rear tires are 32 pounds. The Hoosiers are 21.6 pounds. 10.4 pounds per tire savings and 20.8 total.
So front and rear that is 69 pounds of rotational weight. So race weight at the track without the driver would be about 3511. Maybe with a little less gas in the tank and we are talking 3495 pounds. Getting better all the time.
Edit: Found the front wheel weight of 22 pounds.
Edit: Rear drag wheel with Hoosier tire weighs 42.2 pounds.
Old 05-14-2014, 02:42 PM
  #424
Old School Heavy
You got the power to weight. Now you just need the rubber to the track.
Old 05-14-2014, 03:00 PM
  #425
1989GTA's Avatar
Yep, that is what the shake down passes are going to tell me. Probably go to the local 1/8 mile track first.
Old 05-24-2014, 12:39 PM
  #426
1989GTA's Avatar
My center console showed up today. Here are a couple pictures.
Before the installation.
Installed.
Old 05-24-2014, 09:11 PM
  #427
Long Beach GTO's Avatar
Ya gotta stop adding weight to it if you wanna run with that guy from Florida!
Old 05-24-2014, 10:42 PM
  #428
1989GTA's Avatar
You are right. Going to be hard pressed to beat him. Fortunately it pops right out. My floor mats and everything in the trunk will be out of the car come race time.
Old 05-25-2014, 07:56 AM
  #429
Old School Heavy
Nah, were Buick guys. His console is probably lighter than mine. Mine is partially made of cast pot metal. We wont even get into the 80 lbs of sound deadened we both added. LOL
Old 05-25-2014, 11:21 AM
  #430
1989GTA's Avatar
I did put my console on the bathroom scale just to see how much it weighs. The scale did not record the weight. It is on the light side.
Old 05-25-2014, 02:42 PM
  #431
Old School Heavy
My factory console is 14 lbs if I remember correctly.
Old 05-26-2014, 01:47 PM
  #432
1989GTA's Avatar
Took my car over to my friend Pat's house to do a look see in preperation for the track. Found out the rear tire/wheel combination weighs 57 pounds on his scale. The Hoosier rear tire/wheel combo on his scale reads 43 pounds.
So that is a 14 pound difference per side or 28 pounds total on the rear. After weighing the front tire/wheel combo and the skinnies on his scale it looks like there will be a total of about 75 pounds rotational weight savings at the track from swapping out the front and rear tires.
Remember my car weighed 3580 on the scales. So at the track we will be down to 3505. With a little less gasoline in the tank it will be easy to get down to 3490. Now it is time to quit talking and get to the track and see what she will do.
Edit: How can I forget my floor mats. With the rubber bottoms they are an easy 10 pounds. With the gasoline savings we are down to 3480.
Old 05-28-2014, 02:19 PM
  #433
Hart_Rod's Avatar
How's the thermostat working as far as temperatures? Have you logged your tranny temps yet to see what they are doing? Have you got your TUTD to work yet? If so, will it work in "D" as well as "M"? TIA
Old 05-28-2014, 02:39 PM
  #434
Old School Heavy
If you are under 200 pounds, your raceweight would be under 3700. With your power, that thing should trap at least 124.
Old 05-28-2014, 04:12 PM
  #435
1989GTA's Avatar
Thermostat is working great. Temperatures around town run 192-200 as that is what I have fan 1 set for. On the highway depending on the OAT 175-180. No log of the tranny temperatures yet. On my list of things to do. As of now I don't think I need TUTD the way I drive the car. The car downs shift very good as it is.
As to the track weight it will probably be closer to 3740 including my helmet and with me driving. If my racing friend does the driving then we are talking 3640 or so. Going to the 1/8 mile track this Thursday evening(tomorrow) for some shake down runs. One is to make sure my car is shifting at the correct speed/rpm and how well the chasis reacts including the tires hooking up. Should have results posted sometime this Friday. Density/Altitude will be a little high but that is the way it goes for this time of year.
Speedtigger, what seats are those in your car?
Old 05-28-2014, 08:38 PM
  #436
Old School Heavy
They are from ProCar. They are a really great match for the interior and notably lighter than factory buckets. Price is good too.
Old 05-28-2014, 09:02 PM
  #437
1989GTA's Avatar
Thanks, I was looking at I believe the Procar Elite model.
I think the plan at the track tomorrow for the first couple of passes will be to just see how the car is hooking and how it is shifting. The problem is I think the car might be capable of a 6.99 pass. If that happens we will be asked not to run the car anymore. So we will have to sneak up on all out run. There are some track rental days where things are a little more relaxed. Those will be the ones where I can make the Bonzai 1/4 mile runs.
Old 05-29-2014, 01:25 PM
  #438
1989GTA's Avatar
Saw this post by Vararam on another forum. It is about the intake manifold I posted on page 20, post 389 of this thread. I sure hope this comes true. I am at the point where horsepower is hard to come by with out spending major money such as on aftermarket heads. Here is the post.
"The VRX manifold
General Q & A update.
WE hope this answers some of the questions that have been posed on this forum.
Does it fit under a Camaro Hood? – YES, it does. In general if something fits under a Corvette hood, it will fit under almost anything.
Look Of the unit- The manifold shown is a rapid prototype in Glass nylon for testing on cars and on the Dyno.
You can expect to see Gray or Black Plenums with Red lettering and Gray or Black Runners.
This all depends on the final molded “LOOK”. We will leak this out on multiple forums to judge reaction.
Power- There is a substantial amount of power to be gained from a stock car and even more from cars with a cam, heads/ cam or larger cubic inch combinations. (my add on)
We will have numbers for you soon. We have been testing to dial in closer to each combination to generate the maximum power from each. All combinations will very, however, RPM range and general flow rate from the most common head combinations is about the same.
Price- The unit will be competitive with the current polymer manifolds that are on the market.
Send us any questions you have via PM or vararamindustries@gmail.com
VR tech"
Old 05-30-2014, 01:04 PM
  #439
1989GTA's Avatar
Well, things did not go so well at the track. The better news first. Had trouble launching the car. I think this combination needs a higher stall torque converter. It now has a Yank SS3200 which is probably a little low for track work.
Anyways we started out with 19 pounds of pressure and the car just would not hook at all. Got back to the pits and the pressure was up to 21 pounds. So we dropped it back down to 19 pounds again. It ran a little better. So we dropped the pressure down to 18 pounds and got the best run as shown in the picture. Car was still not launching right.
I beat everyone I was up against and every time they got me off the line but I was able to run them down.
So now for the bad news. On the final and 4th run I hurt the motor. It may have already had problems as the oil consumption was way higher than it should have been. This was a junkyard motor. Anyways back at the pits it was making a chirping sound which I thought was the belt, water pump or maybe the idler pulley. Decided to call it a night. On the way home the motor started to make some noises like a rod knocking sound. The oil press dropped to 20 pounds. I called a tow truck. Personally I don't think the motor was 100% to begin with do to the higher oil consumption.
So it looks like a new short block is in order. I am looking at a Texas Speed 416 short block with around 11:1 compression. The difference in price versus the 376 short block is only like $500 so that is probably the way I will go. So the car is going to be down awhile while I build up my funds.
Old 05-30-2014, 03:12 PM
  #440
Hart_Rod's Avatar
That suxs.......
Quick Reply: My 1965 Buick Skylark L92/6L80 Swap
