AC bracket?
Old Aug 21, 2012 | 10:29 AM
blue98Z's Avatar
Default AC bracket?
We're doing a LSX swap into a 1978 El Camino. Is there a bracket you g body guys are using to relocate the AC up top or are you notching the frame to keep the stock bracket? Any links, advice, help is greatly appreciated.
Old Aug 21, 2012 | 10:50 AM
bronx_peanut's Avatar
What I used was the Kwik bracket and a Sanden 508 compressor. You can find the bracket at www.kwikperf.com there are also some similar on ebay.
Old Aug 21, 2012 | 10:58 AM
blue98Z's Avatar
Thanks man I'll check them out.
Old Aug 21, 2012 | 03:16 PM
blue98Z's Avatar
Anybody else?
Old Aug 21, 2012 | 03:22 PM
blue98Z's Avatar
We have all the accessories. The above kit requires a different compressor. We'd liketo be able to use it if we can. My dad said he read somewhere that the 96-03 vortec s10 bracket will work but hasn't been able find that info again. I don't think it'll work due to the water pump. Not to mention having to drill holes to locate the bracket properly.
Old Aug 21, 2012 | 04:31 PM
74modified's Avatar
Try this
https://ls1tech.com/forums/conversio...e-answers.html
Old Aug 21, 2012 | 05:44 PM
lolife55's Avatar
Haven't used it, just found it couple days ago but holley has come out with some brackets for LS acc.
http://paceperformance.com/i-9456843...acket-kit.html
Old Aug 21, 2012 | 10:19 PM
lt4malibu's Avatar
https://ls1tech.com/forums/conversio...-solution.html
Old Aug 22, 2012 | 08:41 AM
blue98Z's Avatar
AWESOME!! Got what I needed. Thanks a bunch guys!
