Transmission Lines options ?
I plan to run the lines from the trans, on top of the Subframe and around the A-Arm and then to the Trans/Cooler.
1) I could run Teflon Lined Stainless Steel -6 Hose from trans to cooler with AN fittings. This is the easy route, Not sure what Sanctioning Bodys have on rule restriction on what can be used on the Tracks (Auto-x or Drags) or how much can be used.
2) Bend up some 3/8" Stainless Steel tubing and get the AN -6 Bunts brazed on. Then use some short Stainless Steel Teflon Linesd Hose and AN Fittings.
Also.. what do you guy do for the external cooler, before or after the Radiator ?
Just a few suggestion is all that is needed.
Thanks..
BC
trying to bend up some 3/8" SS tubing now for the lines, if that doesn't turn out, I'll just run -6 AB fittings with Teflon Line SS hose.
BC
I was going to run the OEM stock lines, but the Headers were in the way as they were close to bell housing and covering much of the stock routing of the lines, I would have had to Bend the lines lower to almost the bottom of the Bell Housing.. didn't want to take a chance of something on the road coming into contact..speed bump, etc..
They are Edelbrock Headers.. so I figured it be best to run out the side of the trans and up the subframe to the front, just have to route around the A-Arm and support bracket.
Will see how good of a job I do on beding the SS Tubing. I know, if it was Alum or steel, It might be easier. But that me.. overkill and do it the hard way .... LOL.. Once of these days, I'll learn to just take the easy way...LOL
BC
I am pretty sure that thing could cool a freight train. ;-) Mine is only about 1/2 exposed to good airflow. I do not and would not recommend using the radiator trans cooler unless you drive your car in the winter. The radiator warms it up faster and keeps it warmer.
